Old 03-17-2011, 07:24 PM
E220 E220 is offline
Vehicle: 2011 Dodge Ram 1500
Rep:82
E220 will become famous soon enough
Default shifter
so i purchased a new carbon fiber dash kit
just wondering how do you remove the shifter so i could lay the material on and then how do you put it back on
Old 03-17-2011, 10:27 PM
Krpto1973's Avatar
Krpto1973 Krpto1973 is offline
Vehicle: 2011 Dodge Ram 2500 4x4
Trim Level: Power Wagon
Color: Blue
Rep:71
Krpto1973 will become famous soon enough
Can I ask a question about the kit itself? Are these replacement pieces for the existing dash panels, or are they stickers, or overlays, or what?
If you go out to the Mopar website, to the e-store, some of the items like the radios have atatched installation documents. Those docs include step by step instruction of how to take the dash and center console apart. If you can't find the docs, let me know and I will get the URL for you.
-2011 Dodge Ram 2500 4x4 Power Wagon
-2006 Suzki GSX-R 750, 2004 Triton Tr-19x
Old 03-18-2011, 12:07 AM
cudase's Avatar
cudase cudase is offline
Trim Level: Sport Crew Cab
Color: Mineral Gray Metallic
Rep:53
cudase will become famous soon enough
From gunslinger.com, It is very easy to remove the shifter if you are talking about the center counsel
the factory handle is held on with a compression fitting. Inside the grip of the factory shifter, there is a small bump that fits into an 1/8" grove on the steel shaft of the factory shifter. When the chrome plated plastic compression fitting is placed over the bottom of the shift handle, it compresses this grove into the steel shaft. This is what holds the grip on the shifter.
To remove the factory handle, using a butter knife, pry the chrome compression bezel down. After the bezel is lowered, you will see white plastic fingers with slots. The bump is located on the underside of these fingers. Insert a screwdriver into these slots and twist lightly from side to side to free. Pull up to remove the factory grip, then remove chrome compression bezel.
Old 03-18-2011, 12:16 PM
Rep:82
this is a dash kit by B & I which goes i am assuming over the shifter so i would assume i would have to remove the shifter in order to put those pieces in.
If i take out the shifter and that chrome bezzel can i put it back on
Old 03-18-2011, 09:42 PM
cudase's Avatar
Rep:53
Yes, as long as you don't force anything it will come apart correctly and can be put back on.
B&M Floor shifter srtsir Dodge Ram General Discussion 2 11-10-2010 04:14 AM
Pulling off shifter on the '10 Ram USC Ram 2010 Dodge Ram Forum 3 05-22-2010 12:10 AM
Shifter knob EARLJAM Dodge Ram General Discussion 0 05-17-2010 12:57 AM
Ram Replacement Shifter? Texas Hemi 2009 Dodge Ram Forum 7 03-11-2010 01:20 AM
Need Help ASAP Shifter! cue244 Body & Interior 4 04-27-2009 09:36 PM
