Old 03-17-2011, 08:49 PM
Hellspawn1 Hellspawn1 is offline
Vehicle: 2011 Ram Sport Crew 4 X 4
Trim Level: Ram Sport 1500 Crew
Hellspawn1 is on a distinguished road
Question 2011 Ram Crew Cab 1500 4 x 4 Lift Question
I wanted to run 37 x 13.5 x 20 tires on 12 inch rims on my new 4 x 4 Ram.
I was planning on a 6 inch suspension lift but wanted to know if I need to go higher and by how much.
Do I have to go with a 3 inch body also?
Old 03-17-2011, 08:57 PM
a 6 inch should be more than sufficient for 37's. I run 35's on a 4" lift and 18" wheels a +18mm offset with no problem at all.
Old 03-18-2011, 07:56 PM
ScatPak07's Avatar
Rep:970
You have a 4th gen ram so you can fit 37s with a 6" lift alone. If you want to go higher for looks then you will need to use a body lift to get more inches. If Big Horn 4 Life is around he has a 4th Gen ram as well and he has a 8" lift with 37s. He used a method like I mention below to get a little higher. The 6" lift does say 37s are useable so you should be alright. If you had a 3rd gen Ram then you would need to go higher then 6" to fit 37s
There is a trick to get a couple inches that you can use. I am doing this right now....well soon. You can get the Bilstein 5100s and use those up front to gain anywhere from 0-2.5". They have 3 settings that you cna raise it at which are .5", 1.5" and 2.25". If you do use that method I would recommend sticking around the 1.5" mark. To match the rear you cna use a spacer on the rear suspesion.
Old 03-18-2011, 07:58 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
A big hello and a warm Carolina welcome. Don't forget to drop by the newbie section and introduce yourself.
2009-2011 2" Mopar lift for 2009-2010 Ram 1500 trucks glennfrey Suspension 17 02-24-2013 11:51 PM
2WD 1500 7" CST lift 08ChrisRam Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 11 06-17-2011 06:57 PM
1500 7'' lift & 37''s help magnusdeus24 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 01-07-2011 11:32 AM
2011 chrome rims to 2004 1500? 04hemi4x4 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 01-04-2011 11:21 PM
2011 ram 1500 11REDRAM Newbie Checkin! 12 12-17-2010 11:45 AM
