Old 03-12-2011, 08:31 PM
BCWhite BCWhite is offline
Vehicle: 2003 Dodge Ram ST 4.7L V8
Rep:14
BCWhite is on a distinguished road
Default Check Engine Light
Add the check engine light to the other 2 (Airbag and Seatbelt) that are lit up on my console. I cleaned, oiled and replaced the air filter. Drove it about 30 miles and the check engine light illuminated. Maybe I sprayed too much of the recharger on the air filter? I used the K&N recharge kit yesterday, cleaned it out, dried it, then applied the oil. Put it back in and no problems till about 30 miles then the light came on. Looks like a trip to the parts store for a code reading to me.
Old 03-12-2011, 08:33 PM
Rep:1845
I suppose it's possible but you'd really have to lay the oil to it to cause a problem.
Old 03-13-2011, 12:39 AM
Rep:14
I think I may need to inquire about purchasing a code reader. It may save some $$ and time in the future.
Old 03-13-2011, 12:46 AM
I'm guessing that's what ya did. Did you get the code?
Old 03-13-2011, 12:50 AM
Rep:14
No, its too late to get one. I may have over oiled it and some got on the sensor. Gotta get a code tomorrow, might buy a reader, and figure it all out. Shouldnt be too hard to fix and reset.
Old 03-13-2011, 12:58 AM
Rep:14
Ok, I did the ON, ACC, ON, ACC, ON, ACC trick and got P0301. Google says its cylinder 1 misfire. Do I just disconnect the battery and let it reset? I think I might need to put better than 87 in the tank as it hesitates at the beginning of 2nd gear. Still need fixes for the Air Bag and Seat Belt light.
Old 03-13-2011, 01:09 AM
05atlanticblue's Avatar
05atlanticblue 05atlanticblue is offline
Vehicle: 2005 dodge ram
Trim Level: sxt
Color: atlantic blue
Rep:197
05atlanticblue has a spectacular aura about05atlanticblue has a spectacular aura about
a little off topic, if you are planning on getting a code reader - spend the few extra dollars and get a superchips flashpaq, it has a code scanner in it.
Old 03-13-2011, 01:35 AM
Rep:14
Will do, Good idea.
Old 03-13-2011, 02:33 PM
RumbleRam's Avatar
RumbleRam RumbleRam is offline
Vehicle: 2002 Dodge Ram QCSB 4.7L
Color: Light Almond Pearl
Rep:30
RumbleRam is on a distinguished road
just pull your number 1 coil pack off and look at the ground connection to the motor see if it's rusted up, then take the plug out and look at it check it for gap clearance, if it was a injector it would throw up a different code saying injector failure
this is where i go to check codes if i cant get it read that day
http://www.allpar.com/fix/computer-codes.html
Old 03-13-2011, 05:50 PM
Rep:14
Maintenance Day- Got up under the hood and noticed the sensor was partially out from the left side of the intake tube. Took the tube off and cleaned it all up, reinserted the sensor, disconnected the battery and reconnected. Viola, no more check engine light. Changed to Mobil 1 5W30 also, I like how it feels. Now to figure out the Airbag and Seatbelt lights.
check engine light code, please help interpret! MOPAR stallion 5.9L V8 Specific Topics 7 12-02-2010 12:15 AM
Check Engine light col Oil Change 14 11-26-2010 10:23 PM
Check Engine Light on? sixwheeler 5.9L V8 Specific Topics 1 11-10-2010 04:11 PM
180 stat throws on check engine light? MoparMadness08 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 14 08-19-2010 08:22 AM
Check engine light col 2009 Dodge Ram Forum 14 12-11-2009 06:34 PM
