Old 03-18-2011, 03:25 AM
sullivan's Avatar
sullivan sullivan is offline
Vehicle: 2006 Dodge Ram Sport 5.7
Rep:202
sullivan has a spectacular aura aboutsullivan has a spectacular aura aboutsullivan has a spectacular aura about
Default Best way to level my 06 ram 1500
Finally got my suspension ready to put in. However, I am going to replace my inner tie rods. So I am going to wait. However, what is the best way to level the front of my ram? I have brand new stock sized bilstein's ready to install. I put the spring mounts, springs and everything on them.
Are the readylifts the best way to go? I don't want to stress out anything. And I will be replacing all ball joints as well.
This my choice? : http://www.readylift.com/c-147-dodge...11-4wd-20.aspx
06' Sport - 3.92 Gears - Superchips - Bilstein Shocks - HellWig Anti-Sway Bar - Cooper Zeon LTZ - Viper Alarm & Remote Start - Halo Projector Lights - 5k HID Lows & Fogs - Custom Emblems - Magnaflow - CAI
Old 03-18-2011, 04:24 AM
AKRAM's Avatar
AKRAM AKRAM is offline
Vehicle: 2007 Dodge Ram 1500
Color: Inferno Red
AKRAM is on a distinguished road
Hi,
Check out Hell Bent Steel. hellbentsteel.com. they have the levelling kits for your truck for 79 bucks. I have the 2.5" on mine and they shipped it to AK for free. Nice quality too.
Old 03-18-2011, 01:54 PM
sullivan's Avatar
Rep:202
Ill check it out, thanks man.
Keep it coming guys, I need more input. ^ that one too.
Looks like when you level a truck, I would need new sway bar links that are longer as well. It states this on their site. It says it will stop the stress being put on the lower ball joints. AKRAM, did you get new sway bar links too?
Old 03-18-2011, 02:20 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
Guys around here swear buy the bilstien 5100 ride height adjustable shocks for 1500s, a little more expensive then a spacer but everyone says they ride alot better
I have a Hell Bent Steel 2" on a 2500 and am very happy with it. If you do choose to go with a spacer, that would definitly be the company to go through.
Your 1500 doesnt have a sway bar in the front end. There just for 2500s and older 1500 that have solid front axles. You don't have to replace them when you do a leveling kit either haha
Old 03-18-2011, 08:01 PM
ScatPak07's Avatar
Rep:970
You should have waited for the shocks since Bilstein makes the 5100s which is the best level out there. The shocks are used to raise the spring seat which raises the trucks front end. That by far is the best level out there.
If you are going with spacer the best one is the Daystar kits. This is because they do not use steel like the other guys so you dont have metal on metal contact. This gives a little better ride and comfort.
Ya you dont need to worry about sway bars links. You raise your front get an alignment and drive around town....thats it!
Old 03-19-2011, 12:30 AM
sullivan's Avatar
Rep:202
I think Im going to keep my sport how she is. She sits up higher then the ranchos I had on before. I feel like im riding on clouds with these bilsteins!
Old 03-19-2011, 01:30 PM
Color: Mineral Gray
Rep:177
I don't think I would say Daystar the best spacer. I've actually heard alot of complaints about them anywhere from them compressing and/or cracking over time (which there advertised not to do) to not sitting right from the beginning. I've even seen multiple guys switch from brand new Daystars to HBS spacers and were much happier.
Its not metal on metal like most people think. You keep the stock rubber isolator ring between the spacer and the spring so its no different then how your stock spring is installed
Old 03-20-2011, 03:24 AM
AKRAM's Avatar
Color: Inferno Red
^Yup! Im very happy with the HBS level kit so far. I havent had any issues with it so far. Make sure you take it in for an alignment after the install, as with anything that changes the geometry of the front end. My spacers still look new!
How to properly level your Ram 1500 TRX4 Rob 93ZR1 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 28 08-07-2011 03:07 PM
2009 ram 1500 level kit perry1938 Newbie Checkin! 5 02-28-2011 11:29 PM
Level Kit 2005 1500 zirks2005 Suspension 0 02-22-2011 06:53 PM
2010 1500 4x4 level kit, wheels and tires questions 1500minion Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 7 04-11-2010 02:07 AM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 11:50 AM
