Coolant for 180 TStat swap - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 03-18-2011, 09:56 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Default Coolant for 180 TStat swap
Looking for the HOAT Zerex G-05 coolant for my 2010 Hemi, can't seem to find it in any stores. What coolant should I use when swapping my thermostat and has anyone found the G-05 anywhere....I would love to find the 50/50 mix and I know they make it.
Old 03-18-2011, 11:49 AM
Resident Technician
Rep:1915
If you're going to swap the stat, just drain your radiator into a clean container and reuse what you drain out.
Old 03-18-2011, 04:07 PM
916Timmy's Avatar
Rep:1443
Thanks Randy!!!! Drain from the lower hose?
Old 03-18-2011, 04:45 PM
yamifz1's Avatar
yamifz1 yamifz1 is offline
Vehicle: 2010 Ram 4x4 Sport
Rep:589
yes and open the rad cap to allow air in so as to drain faster.
RICHARD
14" Magnaflow,87mm TB,Vararam CAI,HEMIFEVER tuning,Edge 3000 Stall T/C, ARH Headers,Tinted tail and 3rd brake light, rally stripes,Halo LED 55W HID projectors, LEDs inside and out, and many more options.
Old 03-18-2011, 08:04 PM
Rep:2964
usually on the bottom of the radiator, there is a petcock, sometimes metal, but in the newer vehicles it is likely plastic
when turned it allows the liquid to drain in a controlled flow & easy to shut off too
Draining and Refilling Coolant in my 5.9 Jon89 Heating & Cooling 4 02-13-2011 11:04 AM
Coolant dissappearing sritter Heating & Cooling 13 12-29-2010 05:09 PM
Coolant leaking from AC Compressor...WTF? 96Ram1500 Heating & Cooling 8 09-26-2010 10:08 PM
Coolant leak. Bad rad? bigdaddyII 4.7L PowerTech V8 Specific Topics 17 12-16-2009 08:26 PM
Dodge 1500 Engine swap 1997 318 into a 1998 gourash 5.2L V8 Specific Topics 3 11-19-2009 05:10 PM
