Old 03-18-2011, 05:35 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
Default Gas pedal vibration gone!!!
For all you inclined, I figured out what the hell the vibration is and I'm sure it will take care of all the guys and gals with the same issue. Today turned out to be a beauty of a day, nice and warm and sunny so I started rootin' around inside under the dash tugging and pushing on things and it turns out not to be the gas pedal at all!! It always struck me as something with weight to it and sprung, so I start jerkin on the brake pedal back and forth and side to side and discovered enough movement side to side on the pivot point up by the firewall. So when I look way up by the the arm I see the fairly large return spring which explains the "sprung" feeling when it starts.....now I'm gettin excited, I hop in and go for a rip down the fishing hole road which has a fair amount of washboard. I start into the washboard and let it do its thing, same old rattle that you feel through the gas pedal until I hook my left foot behind the brake pedal and gently pull back towards me and......There it is, Gone, I repeated this several times on the washboard and absolutely no noise, I couldn't feel the vibration in the gas pedal whatsoever. Givr' a Try!! and then you can tell me I'm full of shit....lolol
Old 03-18-2011, 07:45 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
So did you find a fix or just identify the culprit?
Old 03-18-2011, 08:20 PM
Rep:160
I guess I could have mentioned that, I'm going to have to figure how to get rid of the play in the pedal, would that be anything that warranty would cover? Maybe a washer to take up the slack or something. I don't know about you guys and gals but that particular ailment drove up the F####n wall, what a difference it makes when its gone.
Old 03-18-2011, 08:25 PM
So there's some slack there where the spring let's the pedal wobble around? Maybe a stiffer spring is the answer.
Old 03-23-2011, 10:38 PM
Holleywud's Avatar
Holleywud Holleywud is offline
Color: Austin Tan Pearl
Holleywud is on a distinguished road
There may be an adjustment on the pushrod to the master cyclinder. Maybe that will take out the slop in the pedal. Mine doesn't vibrate enough to piss me off yet. Maybe I'll take a peek at it sometime soon. You may be on to something.
Old 03-23-2011, 10:43 PM
BRYFRY BRYFRY is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Sport Crew Cab 4x4
Color: Inferno Red
Rep:32
BRYFRY is on a distinguished road
My gas pedal used to vibrate like crazy, even on smooth roads. I recently put aftermarket wheels and tires on my truck, and now the vibration is completely gone!
...Just FYI.
Old 03-24-2011, 07:48 AM
Rep:160
I'm going to poke around some more when it warms up again, it's minus friggin 30c here this morning!......spring...my ass.
Old 04-25-2012, 12:51 AM
gcgrimes gcgrimes is offline
Vehicle: 2012 Ram 1500
Color: Deep Cherry Red
gcgrimes is on a distinguished road
Hello all.
I am also having the vibration through the gas pedal. After reading many forums, I am convinced there are three types of vibrations different folks are getting through the gas pedal. First, some people feel the road vibration through the tires. Second, some people are getting a vibration/shimmy when at low RPM and the truck is in MDS mode and trying to switch from four cylinder to eight cylinder. I get both of those and those don’t bother me at all, I believe they are quite normal. The third vibration is when the engine hits about 2000 RPM’s it causes a vibration through the pedal and steering wheel that feels like an electric shaver. That third vibration is making me absolutely hate my new 2012 Ram 1500 Big Horn when I drive it on the freeway, because it cruises right at 2000 RPM, the range where the vibration occurs. I have had the truck to the dealer a number of times and they say they can’t feel it. Funny, because the Ken Towery mechanics and my friends can all feel it and say it isn’t “normal”. I have also owned a Jeep Truck, a Ford F-150, and Chevrolet Blazer, and numerous other cars and have never had this happen. I have read many Dodge forums and have not yet seen anybody that has a real solution or received a real solution from Dodge/Ram. If you are having the third issue, vibration through the gas pedal at certain RPM’s, give me an e-mail at gcgrimes@insightbb.com. If I can get enough people having the same problem, maybe we can force the dealer/manufacturer to deal with it. Thanks
Vibration at 60 MPH and cupped tires davidreed 5.7L (345 cu in) HEMI V8 Specific Topics 14 06-13-2013 09:13 AM
Gas Pedal Vibration and Shifting Issues pboiss 2010 Dodge Ram Forum 57 04-26-2012 03:01 PM
Vibration around 2500 rpms lucidanomaly Newbie Checkin! 14 04-25-2012 01:15 AM
Vibration in the gas pedal orange08ram Dodge Ram General Discussion 10 02-17-2010 03:08 AM
'07 1500 4X4 Vibration rottyrott Suspension 7 05-25-2009 11:51 AM
