Old 03-19-2011, 01:44 PM
gtahemi11's Avatar
gtahemi11 gtahemi11 is offline
Vehicle: 2011 Dodge Ram 1500
gtahemi11 is on a distinguished road
Default 305's on stock suspension?
Im waiting on my Bilstein shocks to come in. Was wondering if I can run my new 305/55r20 Trail Grapplers with a 1/4" Spacer on the front wheels and not rub anywhere while im waiting on the shocks? Rims are 20x9 +18 offset
Appreciate any advice
Old 03-19-2011, 02:45 PM
That's a great question. I haven't seen this fitment on a stock 2011 suspension. Hopefully someone has done this and can answer your question.
You could always go down to the tire shop and try a test fit.
Old 03-19-2011, 02:47 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
I think you'd be ok. A 305 is just under 12" wide and about 33.5" while most people run 35x12.5 with a leveling kit/spacer
Old 03-20-2011, 11:48 AM
gtahemi11's Avatar
well i just went and did it just to see if it would work and being anxious. And they fit perfectly with the spacers. No rubbing on the Upper A-arm
Old 03-23-2011, 09:58 PM
D.Rowe's Avatar
D.Rowe D.Rowe is offline
Vehicle: 2005 Dodge Ram 1500 Daytona
Trim Level: Daytona
Rep:121
D.Rowe will become famous soon enoughD.Rowe will become famous soon enough
Just had Cooper Zeon LTZ's 305/55/20's installed on my 05' Daytona with stock suspension and no spacers.
Result..no rubbing whatsoever. So happy.
Dave
Weather Tech mats, 12" Billet Antenna, Recon 60" LED bar, Spyder LED tailights, Map & Dome LED's, Pioneer AVH-P6300BT, Upgraded Tweeters in Dash, Cadence 8" Sub under Drivers Seat
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
07 dodge ram 1500, improving stock suspension. booyah Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 03-14-2011 02:04 AM
is there anybody that sell better than stock replacement suspension parts? steveray Suspension 1 08-09-2010 02:48 PM
Will 32" tires fit on a stock 2010 suspension? USC Ram 2010 Dodge Ram Forum 4 06-20-2010 08:13 PM
Stock Suspension Help JT42 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 6 01-17-2010 07:09 PM
