Old 03-19-2011, 05:48 PM
curt5878 curt5878 is offline
Vehicle: 2011 Ram Sport 4x4 Crew Cab
curt5878 is on a distinguished road
Default Wheel Spacers / Adaptors Will I need them?
Hey guys I'm about to install a set of Toyo Open Country MT on my 2011 Ram Sport. My question is will I need a wheel spacer or adaptor and if so how big? I've already installed the 2.5" front leveling kit and I'm going with a 35x12.5x20 tire on the factory chrome 20" rims. Thanks!
Old 03-19-2011, 06:41 PM
Vehicle: 2005 Dodge Ram 2500
Color: Mineral Gray
Rep:177
I think 1/4" spacer is enough on your truck. I'm sure thers plenty others who could actually confirm this
Old 03-20-2011, 04:39 PM
ScatPak07's Avatar
Rep:970
Yea you will probably need a small spacer since the tires will either rub or be very very close to the suspension.
Old 03-20-2011, 05:07 PM
Rep:2640
if you use any spacers, you will likely also need longer wheel studs
there is suppose to be a certain number of stud threads sticking into the lugs, on older vehicles that had open faced lug nuts, they wanted to see at least 2 full threads beyond the nut,
I'm not sure how they would figure that out with the closed face lugs, maybe a micrometer & some mathematics
Discount Tire told me that they won't use spacers, insurance liability thing
Old 03-20-2011, 06:34 PM
Color: Mineral Gray
Rep:177
1/4" Should be ok with out longer wheel studs. I had 1/2" on a 2500 with plenty of threads as a temporary fix. I wouldnt recomend anything over 1/4" without longer studs
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 157 09-21-2014 08:47 PM
Anyone using 5/16" wheel spacers? xopt1js Dodge Ram Wheels And Tires 4 03-02-2011 03:32 PM
wheel spacers tinniste 079 Dodge Ram Wheels And Tires 9 11-22-2010 04:17 PM
1500 wheel spacers mikescicutella516 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 14 10-22-2010 01:51 PM
Wheel Spacers causing severe Wheel Wobble nantuzzi Dodge Ram Wheels And Tires 3 06-10-2010 10:17 PM
