Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Body & Interior
Old 03-19-2011, 07:44 PM
SINNER SINNER is offline
Vehicle: 1996 Dodge Ram 4x4, 1965 D100
SINNER is on a distinguished road
Default Mechanical oil pressure gauge help w/install?
I just bought the mechanical oil pressure gauge. (Sunpro $18) Is it neccesary to put in a "T" where the existing unit is in order to keep the old unit plugged in? Or can I just leave the old unit unplugged and run the new mechanical one in its place? Also what is the PSI supposed to be at when idling and at throttle? After I check the oil pressure I will tell you what I found. My truck is a 1996 1500 5.9 4x4 it has 196,000 miles on it. Thank you in advance.
Old 03-28-2011, 03:25 AM
984wdram 984wdram is offline
Vehicle: 1998 dodge ram
Color: deep amythest and silver mist
984wdram is on a distinguished road
yes you do need a t fitting. you can find them at lowes with all the reducers and everything if needed. remember teflon tape, had an ex gf's daddy help me put one in my old s10 and he didnt use teflon tape, all the oil leaked into the x-member, so i couldnt see it leaking...motor blew. the oil pressure sending unit, at least on my s10, also controles the fuel pressure too. should read between 30-60 pounds. and up from there with rpms.
Old 03-28-2011, 07:39 AM
Resident Technician
Rep:1915
At a minimum, you should have 10 psi for every 1000 RPM.
Directions for installing mechanical oil gauge? SINNER 5.9L V8 Specific Topics 0 03-19-2011 12:27 AM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
Oil Pressure Gauge Goin Crazy? carnage 5.9L V8 Specific Topics 18 05-31-2010 12:58 PM
oil pressure gauge chuck51003 5.9L V8 Specific Topics 2 05-20-2010 08:58 PM
dtc po148 nachizzle Cummins Diesel Specific Topics 2 06-09-2009 12:36 PM
