Sway Bar Links - HELP! - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 03-19-2011, 11:05 PM
ktm1217 ktm1217 is offline
Vehicle: 1999 Dodge Ram 1500
Trim Level: SLT Laramie
ktm1217 is on a distinguished road
Default Sway Bar Links - HELP!
Hey, I have a 99 Ram 1500 4x4 reg cab, short bed that is in need of a passenger side sway bar link. I'll prob do both links just to get them done and so I dont have to worry about them. However, the truck has a 5" Tuff Country lift kit and dual steering stabilizers up front. My question here is can I buy OEM links or do they have to be bigger/aftermarket ones because of the lift kit??
Old 03-19-2011, 11:50 PM
FormerGorilla's Avatar
FormerGorilla FormerGorilla is offline
Vehicle: 2010 Dodge Ram 4x4 Crew
Rep:147
FormerGorilla will become famous soon enoughFormerGorilla will become famous soon enough
As I researched a couple lifts online, most appear to come with Sway Bar drop brackets and do not mention having to swap end links, and they don't come with end links. I would say that since aftermarket end links are not part of the original kit, then factory ones are likely used. I would say that you best bet would be to take one to your local auto parts store and compare the length of yours to the OEM replacement. If they're the same, I'd venture to say your good to go.
MODS LIST! -- 20% Tint, Curt Rec. Hitch, Slimline Toolbox, Huskyliner mats, Huskyliner Mud guards, 18" Gear Wheels, 33" Hankook ATM Tires, Bilstein 5100's at 1.4", Ported Foxbox w/2 10" Polk Subs & JL 500W Amp, Mufflex 24" Exhaust, Tow Hooks, Dominator II Step Bars, GatorHyde Spray-In Bedliner
Old 03-21-2011, 02:26 PM
Thats kinda what I was thinkin of doin also, but I'd figure I'd see what some of you guys said first. I guess that will be the plan then. Thanks!
Worn sway bar bushings.... sullivan Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 03-03-2011 09:40 AM
Is this HBS sway bar drop kit installed correctly? jeepinoutwest Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 1 02-07-2011 10:45 PM
new for 09-10 ram sway bars - addco SPEEDFREAK Custom Chassis - Drive Line - Suspension - Wheels and Tires - LOWERING or STANDARD 16 01-05-2011 08:03 PM
sway bars strang3majik Suspension 0 06-10-2010 01:28 AM
