Old 03-20-2011, 10:24 AM
backsaw13's Avatar
backsaw13 backsaw13 is offline
Vehicle: 2001 Dodge Ram 1500 Quad Cab
Color: Graphite Metallic
backsaw13 is on a distinguished road
Default 305/70/16 - to - 265/75/16
I am looking at replacing tires on my 2001, it currently has nikko terra graplers 305/70/16 - on stock rims - I am unsure of what lift is on the truck, as I just purchased it, and the prior owner did not know. I was considering the Hancook DynaPro ATM - but the same size is not available - and I don't want to go any wider or more expensive...what would the 265/75/16 be like compared to the 305? Feel, Look, Noise?
Anyone have the hancook on their truck in this size with pics?
Thanks.
Old 04-18-2011, 12:07 AM
ajake's Avatar
ajake ajake is offline
Vehicle: 2001 dodge 1500 ram
Trim Level: laramie xlt
Color: intense blue
ajake is on a distinguished road
Default well
your looking at about a 5-6inch drop in the height of the truck and im guessing the 305's where a little agressive because of the size so the sound could be less whiney , and there will be more space between your tire and wheel well , alot more space ... and because of the size tires on currently i'd guess theres at least a front leveling kit.
Old 04-21-2011, 06:57 AM
jcasey10's Avatar
jcasey10 jcasey10 is offline
Vehicle: 2002 Dodge Ram
Trim Level: SLT Quad Cab
Rep:869
Well, seeing as you have the Sport, I think most of them came with like a 2 inch lift from the factory. That's why the 305's actually fit. Now, going from a 305 down to like a 265, you're gonna see a pretty big difference. First off, the truck will sit a little bit lower, but not 5-6 inches lower. The tires will be a lot thinner and won't stick out past the fenders. And you might feel a little difference handling like there's more body roll then what you're used to. If it were me, I'd get a 275 or 285/70/16.
305/70/16 on stock wheels yosemite1977 Dodge Ram Wheels And Tires 0 11-11-2009 08:47 PM
