Old 03-20-2011, 03:58 PM
chaccof chaccof is offline
Vehicle: '05 Quad cab, 4.7l 4x4
Trim Level: Standard
chaccof is on a distinguished road
Default Intermittant Stalling Issue
Have an '05 1500 4.7 with 84k on it. Over the last two months the truck has had an intermittant stalling issue - primarily first thing in the morning, usually when I throw it into D after backing out of my driveway or after braking for the first stop sign I come to...just flat out stalls....no sputter, just stalls. Every once in a great while it will happen after the truck is warmed up. Any thoughts?
Old 03-21-2011, 01:27 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Have you replace spark plugs, air filter, etc. The stalling issue is quite common when the spark plugs are past 'end of life'.
brad
Interested in one of my mods?
Old 03-21-2011, 08:15 PM
Yeah, replaced them about 8,000 miles ago. Did not change out wires, but the wires looked okay....
Old 03-21-2011, 10:22 PM
RumbleRam's Avatar
RumbleRam RumbleRam is offline
Vehicle: 2002 Dodge Ram QCSB 4.7L
Color: Light Almond Pearl
Rep:30
RumbleRam is on a distinguished road
i dont think the 2002-2007 4.7L has plug wires....just clip connectors, check your power steering fluid, my was really low once and i was turning the steering wheel while putting it in drive and it stalled on me,
Old 03-21-2011, 11:29 PM
brad12kx's Avatar
Rep:2581
Have you cleaned the throttle body?
brad
Old 03-22-2011, 10:37 PM
Yep, cleaned the TB same time as I replaced the plugs.
Old 03-22-2011, 11:35 PM
brad12kx's Avatar
Rep:2581
Have you had the MIL (check engine light) come on? If so, did you read the codes?
If you have access to a code reader, can you check if there are any 'pending' codes.
Fuel pressure is another place to look. Not sure if this would generate a code or not, but if the problem is only when it's cold, then this could be a possibility.
brad
Old 03-25-2011, 11:03 PM
pendleton14 pendleton14 is offline
Vehicle: 2007 Dodge Ram
Trim Level: stl 4x4
Color: graphite black
pendleton14 is on a distinguished road
my 07 had a stalling problem like that after I had the trans fluid change. Had to do with the new filters not being seated completely and it was sycking air instead of fluid. Had it redone and so far no problem
Stalling issue coming to a stop Paul G. 5.7L V8 Specific Topics 22 03-06-2014 12:34 AM
Fixed My Stalling Issue (hopefully) BlownAMC 5.7L V8 Specific Topics 5 10-05-2012 11:06 AM
Stalling issue DYNO 5.7L V8 Specific Topics 20 05-12-2011 09:43 AM
07 stalling issue pendleton14 5.7L V8 Specific Topics 7 03-06-2011 12:25 AM
stalling issue 971500 5.7L V8 Specific Topics 2 05-30-2010 08:19 PM
