Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 03-22-2011, 09:38 AM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
take ur air box off and open your throttle plates and look down inside the intake with a flashlight and see if there is oil puddling in the bottom of the intake, if there is then its bad for sure. also another way is to take off your oil fill cap and put your hand over the hole too see if you feel any suction.
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 03-22-2011, 09:19 PM
015.2Ram 015.2Ram is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: XLT
015.2Ram is on a distinguished road
If I see oil is that a bad bad thing. Seems to me it is just ganna burn it off? How is it getting there? If that gasket is fixed will all be ok then. If I see oil should I get it fixed right away, will driving it more in that state, will it hurt it?
If I get suction I assume that means the gasket is going out?
Old 03-23-2011, 07:40 AM
98redbull2's Avatar
Rep:52
if theres a little around an edge its not really bad, but if there is oil pooling in there its gonna burn it and consume the oil going in there thus having to add oil every once in a while. but if there is more than just around the edges it should probably be fixed because that is an oil leak, oil consumption, and vacuum leak all in one and that hurts ur MPG'S! your going to wanna get it fixed. not so much that its gonna hurt it but not really good for it. I think you should do it as soon as you can.
Old 03-24-2011, 12:57 PM
Trim Level: XLT
thanks folks. I will look at it this weekend.
Old 03-24-2011, 02:23 PM
Trim Level: XLT
I pulled the air intake and it was clean inside there, saw no oil puddling or any sign of oil using a flashlight and what I could see. Did see some black gasket I assume it was mated to the intake inside there. It looked fine, no degrading going on with the parts of it sticking out.
Old 03-25-2011, 03:22 PM
98redbull2's Avatar
Rep:52
gasket should be good for now then, only when you see the oil in there
