alternator issues - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
Old 03-21-2011, 07:24 AM
backswamp backswamp is offline
Vehicle: 2004 dodge ram
Trim Level: lt
Color: blue
backswamp is on a distinguished road
Default alternator issues
I have a 2004 1500 with the hemi engine. This weekend had to replace the alternator as well as battery. New alternator was not charging battery and my volt meter on the dash was low and then after 30 seconds it went to zero and check gauge light came on. Figured I got a bad alternator so took the new one off, returned it, got a new new one and it is doing the same thing. If anyone has any advice it would be much appreciated as I sure would like to make my youngins ballgame when i get off work
Old 03-21-2011, 08:24 AM
Rep:3347
Any belt squeal? Grab a volt meter and check across the battery posts with the motor running and check the alternator output, it should be around 13.5-14. If it's not, check to be sure the serp belt is turning all the pulleys.
Old 03-21-2011, 09:40 AM
Trim Level: lt
Color: blue
no belt squeel, the newest alternator was tested and it was showing no output. i doubled checked the two connections to the alternator and they appeared good, checked the wiring from the alternator back to panel box and no signs of frays. while i have bad luck i would hate to think i got two new alternators from the store and both of them bad. belt is running smooth and is turning the alternator
Old 03-21-2011, 09:54 AM
Resident Technician
Rep:1915
Have you got 12V on the battery wire at the back of the alternator?
Old 03-21-2011, 12:17 PM
Trim Level: lt
Color: blue
there were no wires on the back of the alternator that i took off however the back of the alternator does have two screws or screw posts on the back of it that i am unsure of. don't know if they are there for internal parts or if a wire may have come loose from the old alternator
Old 03-21-2011, 02:14 PM
Trim Level: lt
Color: blue
spoke with Remy Power Products and they advised that the alternator is fielded by the PCM and this is what turns the alternator on. They advised to test to see if it is being fielded. Anyone have any idea if this gone be done in the driveway or does it need to go to a mechanic
Old 03-27-2011, 04:21 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
There are 2 wire connections on the rear/near the rear of the alternator. A plug with 2 thin wires (field) and a heavier one with an eyelet that attaches to the output stud (battery). If these wires are not connected, the alternator will NOT work. If the heavier one was disconnected and allowed to touch ground with the battery cables on, then the fuse-link for it will be blown and the alternator will not work until the fuse-link is replaced.
brad
Interested in one of my mods?
Old 05-03-2011, 10:44 PM
firedog828 firedog828 is offline
Vehicle: 2004 dodge ram 1500 4x4
Trim Level: laramie
firedog828 is on a distinguished road
i'm having the same problem. where is that fuse link located???
no one can force me to run into burning buildings to save hot chicks!...I'M A VOLUNTEER!!!!
Old 05-03-2011, 11:01 PM
brad12kx's Avatar
Rep:2581
Usually it's close to the battery. follow the battery wire from the back of the alternator to it's connection at the battery or IPM. Somewhere near the battery, this line will have a elongated bump, or what looks like a splice connection. The fuse link is a piece of wire designed to burn up and disconnect the circuit in the even of an overload.
brad
Old 05-03-2011, 11:47 PM
Trim Level: laramie
ok thanks! if by chance that is not the problem what else could it be?? broke wire??
