Help! Towing capacity 2010 Ram 1500. - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Towing
Old 03-21-2011, 11:48 AM
westxsrt10's Avatar
westxsrt10 westxsrt10 is offline
Vehicle: 2010 Ram 1500 4x4 Hemi
Trim Level: Cool Chrome
Color: Cool Vanilla
Rep:79
westxsrt10 will become famous soon enough
Default Help! Towing capacity 2010 Ram 1500.
I can't find the real towing capacity for my truck....the Ram site won't allow me any options.
2010 Ram 1500, crew cab, 4x4, auto, Hemi, 3.92 rear end, 20" wheels. My rear end got hot towing 8000lbs and that dosent seem right.
2010 Ram CC 1500 Hemi 4x4, 3.92 Mag-Hytec diff. cover
2008 Viper coupe, Belanger ceramic headers
2008 Ford F-250 CC,4x4,V-10
Old 03-21-2011, 03:28 PM
BigThirsty's Avatar
BigThirsty BigThirsty is offline
Vehicle: 2004 Dodge Ram 2500 4X4
BigThirsty is on a distinguished road
How hot did it get and what are you basing too hot on? 8k is quite a bit so I'm sure it heated things up.
2004 Dodge Ram 2500 4X4 5.7
Old 03-21-2011, 04:50 PM
westxsrt10's Avatar
Color: Cool Vanilla
Rep:79
I have a laser type thermometer...it read 285F, so i'm sure it was hotter while towing (the rotton dead smell occured too).
A reg. cab. long bed, 3.96 gear, 17" wheel, Hemi truck says it can tow 10,250lbs. I'm hoping to find the specs. for my truck?
Old 03-21-2011, 06:38 PM
BigThirsty's Avatar
Although I'm not aware of a heat spec on a rear diff, that is abnormally warm and probably destroyed your oil. I would change to a synthetic and be sure you're using the 75w-140.
It could be your gears are not meshing correctly or have not broke in correctly. If there is any "clicking" when you put it into gear or a vibration when driving I would take it to the dealer and complain. Heck, just take it in a say it started roaring when you were towing and your thermometer registered 285+ just to get them to check the gears. With a 2010 you should still be under warranty. You can also look at getting a finned aluminum cover.
Here are the 2011 specs. They should not be too different are weight ratings are just a numbers game for truck peter measuring contests anyway. http://www.dodge.com/bodybuilder/201...ammlup1500.pdf
Rep:2964
I am not a mechanic, but, i have to wonder IF someone forgot to add the additive for the Limited Slip
time for a trip to the dealership in any case
SLT or TRX
5.7 automatic
4X4
i can find anything on rear ends or tires
Towing[1]:
5000 lbs - std
10250 lbs - max
Payload[1]:
1510 lbs - max
http://www.ramtrucks.com/en/towing_payload/2010/
Old 03-21-2011, 06:48 PM
Gene K Gene K is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Gene K is on a distinguished road
Crew Cab SLT 4x4 3.92 20" - 9900 lb
Crew Cab Laramie 4x4 3.92 20" - 9750 lb
Source: http://www.dodge.com/bodybuilder/201...ammlup1500.pdf
Gene
Old 03-21-2011, 09:30 PM
westxsrt10's Avatar
Color: Cool Vanilla
Rep:79
Thanks for the links guys.
I took the truck in right away to the closest dealer while on my trip to Idaho last week. The dealer said no warrenty because I over loaded the truck, I paid out of pocket to get fluid changed to 75-140w and get my truck back. The truck has 2400 aprox miles on it.
I weighted the trailer empty today (3700lbs) the Viper weight is 3500lbs+ my lawn mower 450lbs. They said the truck is only rated to tow 8000lbs. is I'm building a case against them. (very small dealer in SE Colorado)
Old 03-21-2011, 10:24 PM
uktitus uktitus is offline
Vehicle: 2009 dodge Ram 1500 4x4
Trim Level: Laramie crew cab
Color: Grey
Rep:41
uktitus is on a distinguished road
Some of these dealers are outrageous as well as just plain stupid. The only sensible reason one can think is that some dealers are near the breadline and need cash flow as Chrysler pay slowly?
Old 03-22-2011, 09:30 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2014 Megacab 4wd
Rep:252
call Chrysler direct. it's tough to argue when you are on the road and need to get a move on.
I thought the rear diffs were filled with syn from the factory?
Old 03-26-2011, 11:19 PM
Rear Differential comes with synthetic from factory.
Gene
Dudes please help me out!!! 2010 cummins vs 1500??? Elite Cummins Diesel Specific Topics 31 07-25-2011 04:24 PM
1500 or 2500? PLEASE Help a New Member! bill440rt 2011 Dodge Ram Forum 34 07-02-2011 11:38 PM
2010 RAM 1500 Flip out towing mirrors????? fwmitchell Newbie Checkin! 12 08-05-2010 12:59 AM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 11:50 AM
Are there any differences at all between the 2009 and 2010 Dodge Ram 1500? viper 2009 Dodge Ram Forum 8 10-07-2009 05:26 AM
