Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Towing
Old 03-26-2011, 11:43 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
I looked thorough the charts, and the 'worst case' scenario with the Hemi is -
Laramie, 3.55, P275/60R20, Rambox; and even this is rated as 8150Lbs towing.
The lowest rating I can find with Hemi and 3:92 gears is - 9650Lbs.
Do you have the Ram Box option ?
brad
Interested in one of my mods?
Old 03-27-2011, 01:33 AM
Rep:2657
3.92 LSD needs the special additive
if your vehicle has the wrong differential cover, the fill plug is too low to let oil get to the the axle bearings out by the wheels
you need to become a detective & if you find either of the above things to have happened, squeeze their private parts to the MAX
Old 03-27-2011, 07:57 PM
Jerry K Jerry K is offline
Vehicle: 2011 Dodge Ram Laramie 4x4
Trim Level: laramie
Color: blue
Jerry K is on a distinguished road
i have the 2011 laraime with the same set up. I have towed 5500lbs short dist. with no problems I think 8000 might be overloading your truck..
Old 03-27-2011, 08:13 PM
Rep:2657
i found this article that is useful
http://news.pickup trucks.com/2009/07/2010-dodge-ram-1500-towing-rating-increases-to-10450-pounds.html i have separated the name of the site, so you can find it, it would only have ** if i didn't
Old 03-27-2011, 08:59 PM
Rep:2657
this is the 2011, 2010 should be the same
i'm still confused
5.7L HEMI® V-8
5-Speed Automatic Transmission Towing[1]:
4X4
17" tires
ST model
5000 lbs - std
10250 lbs - max
Payload[1]:
1510 lbs - max Towing[1]:
SLT/Outdoorsman
5000 lbs - std
10250 lbs - max
Payload[1]:
1530 lbs - max Towing[1]:
Laramie
5000 lbs - std
9850 lbs - max
Payload[1]:
1610 lbs - max
Old 03-27-2011, 10:15 PM
westxsrt10's Avatar
westxsrt10 westxsrt10 is offline
Vehicle: 2010 Ram 1500 4x4 Hemi
Trim Level: Cool Chrome
Color: Cool Vanilla
Rep:79
westxsrt10 will become famous soon enough
[QUOTE=Jerry K;484514]i have the 2011 laraime with the same set up. I have towed 5500lbs short dist. with no problems I think 8000 might be overloading your truck..[/QUOTE
Specs say I'm good for 9950 lbs. I changed the gear lube again yesterday to Amsoil Syn EB 75-140w and added the limited slip additive. I'll give it another try in a few weeks on the same road with about the same weight trailer. (fingers crossed, the wifey will be driving solowith me following in the 5th wheel RV) This will be the final trip on the move from Texas to Idaho.
2010 Ram CC 1500 Hemi 4x4, 3.92 Mag-Hytec diff. cover
2008 Viper coupe, Belanger ceramic headers
2008 Ford F-250 CC,4x4,V-10
Old 04-02-2011, 06:21 PM
Trim Level: laramie
Color: blue
good luck. let us know how you make out.
Old 04-04-2011, 01:24 PM
Gene K Gene K is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Gene K is on a distinguished road
i'm still confused
5.7L HEMI® V-8
4X4
17" tires
ST model
5000 lbs - std
10250 lbs - max
Payload[1]:
SLT/Outdoorsman
5000 lbs - std
10250 lbs - max
Payload[1]:
Laramie
5000 lbs - std
9850 lbs - max
Payload[1]:
1610 lbs - max
Curb Weight is lower on some 2011 models which leads to a small change in Tow Rating given the same GCWR.
Some 2011 Trucks also got a raised GCWR which resulted in a higher tow rating. The Crew Cab 4x4 4.7L 3.55 for instance got its GCWR raised to the same as the 3.92 so they are now rated to tow the same.
Gene
Old 07-02-2011, 07:14 PM
bigred bigred is offline
Vehicle: 2010 dodge ram quad cab
Trim Level: crome
Color: infernal red crystal pearl
bigred is on a distinguished road
I d go to a dealer some were else I have had so much problems with were I got mine I will never ever go back there another dealer I called was so helpfull and didnt give me grap on the 12000 mile check up tell them just the trailer weight the smell and noise let them tell ya want they want to do there should have been no problems towing I feel the rear end came with problems its not your falt I have all my oil changes and work on my truck paper work because aftere selling you the truck it seems thats it they wont fix it right pretty sad I think !
Old 10-17-2011, 11:48 PM
dndgib dndgib is offline
Vehicle: 2010 Ram and 2011 Ram
Trim Level: Big Horn / Laramie
Color: White / Blue
dndgib is on a distinguished road
have others had this problem with the 1500? I have a 2010 crew with the 5.7 and currenly tow a popup at around 2600lbs. I want to move up to a bigger camper that is close to the 10,000 lbs. I don't want to destroy my truck. If the truck can't pull it, no reason for me to try it.
Thanks
Dudes please help me out!!! 2010 cummins vs 1500??? Elite Cummins Diesel Specific Topics 31 07-25-2011 04:24 PM
1500 or 2500? PLEASE Help a New Member! bill440rt 2011 Dodge Ram Forum 34 07-02-2011 11:38 PM
2010 RAM 1500 Flip out towing mirrors????? fwmitchell Newbie Checkin! 12 08-05-2010 12:59 AM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 11:50 AM
Are there any differences at all between the 2009 and 2010 Dodge Ram 1500? viper 2009 Dodge Ram Forum 8 10-07-2009 05:26 AM
