Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Electrical
Old 03-21-2011, 05:32 PM
i2c
Unhappy wire code for horn wire at steering column harness needed
Hi everyone,
due to a alarm system install the color code for the horn wire at the steering column harness is needed. Tryed to find it out for hours today.
I would appreciate any help, ideas or suggestions.
Thank you
Old 03-22-2011, 10:39 PM
rlast1 rlast1 is offline
Vehicle: 1994 Ram 2500
Trim Level: SLT Laramie
Color: Green
rlast1 is on a distinguished road
Default Horn Wire
It is a small black wire with a red stripe. This is a negative signal (it grounds when you push horn button).
Old 03-22-2011, 10:44 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Black w/Red stripe.
brad
Interested in one of my mods?
Old 04-26-2011, 04:30 AM
i2c
Thanks alot for your help!
I found the wire and now it works!
Have a good day!
horn button color code
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 16 07-02-2016 05:36 PM
5.2/5.9 Misfire TSB 18-48-98 RamTech Dodge Ram Knowledge Base 3 06-22-2014 07:45 AM
Found out I have a recall :( SslagleZ28 Dodge Ram Recalls and TSB's. 4 03-21-2011 12:23 AM
Remerson228 last airbag question awful knawful 2009 Dodge Ram Forum 5 05-17-2010 07:42 PM
Dash removal/ Heater core replacement Trishafer Heating & Cooling 6 02-25-2010 07:23 PM
