Old 03-22-2011, 12:05 AM
Hosslt1's Avatar
Hosslt1 Hosslt1 is offline
Vehicle: 2008 Ram Quad Cab 4X4
Rep:114
Hosslt1 will become famous soon enoughHosslt1 will become famous soon enough
Default Interior dash light conversion complete!
Hey all. As some of you may have picked up I took the giant leap into the project of converting all my interior lights from the ugly factory light green to red. After about a month of working at this a few nights a week I finally have in finished and am happy with the results. I used an older thread (posted below) for all the led #s and instructions. Its really a good write up and tells you everything you need to know for the install.
http://www.ramforumz.com/showthread....ht=dash+lights
Heres my list of additional pointers:
1. Get the brighter option for each LED you plan to install BESIDES the rear power window switch, For some reason that light is much brighter so I would recommend going with the standard LED. (you will see how much brighter this bulb is in the pictures below)
2. Dont expect to do this in an afternoon. No part of this project is too hard but popping the stock LEDS out of the circuits for the 4x4 switch, light switch, and rear power window switch and soldering in the new LEDs is pretty tedious and can be nerve wreaking.
3. Buy a decent quality solder gun, you will need it
4. The aftermarket LEDs will use less current than the stock filament bulbs you will be replacing. This decreased load will trigger a sensor in your computer and cause the lights to flicker and turn off when the dimmer is turned up. You can either install a resistor (i have no idea what size you would need) or (like i did) solder in another few lights into the circuit, increasing the load. I chose a 24" led strip I got from ebay for about $4, soldered it into LED terminals inside the 4x4 box and installed the strip just below the cup holder hinge, hiding the strip and giving a nice dim red glow on the carpet.
ok...that about wraps up my advice...now for the pictures!
Here you see the back of the gauge cluster with red twist LEDs installed
Same photo with the black cover on the back of the gauge cluster
This is the piece of RED RoscoLux gel "tint" I cut out of the roll ($6 on ebay) and stuck over gear indicator section of the cluster.
Heres the overhead computer circuit stripped down with a piece of RuscoLux tint stuck to it.
This is the back of the overhead control circuit with the new LEDs installed with the old factory bulbs beside each LED
This is the housing which holds the bulb that shines down onto the cup holders. After removing it I found that from the factory they just used a similar tint that I was using (only ugly green) so I simply cut out the same shape of my red tint and put it in the housing (see below)
Finished Product: My phone takes really crappy night pictures so they look all grainy and dim but it really does look great. Like I said the only thing I want to change is the rear window switch's light because its too bring. Even with the poor quality night pictures you can see that it is too bright.
I hope this is helpful to anybody else looking to do this conversion and feel free to ask questions. Thanks for looking!
Bilstein 5100's, Rockstar 20x10 XDs, Tint, de-badge, fender flares, smoked tail/3rd brake lights,
painted interior, Kenwood 7" touchscreen, FOX box, eclipse 10s, memphis mono amp, Complete dash light swap to Red LEDs.
Old 03-22-2011, 12:20 AM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
That is pretty in-depth!!!!
Old 03-22-2011, 12:21 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Nice mods, I think red is a great dash and interior lighting choice. I remember a Mazda I owned in the past that allowed switched color choice.
Old 06-22-2011, 09:50 AM
mrboots's Avatar
mrboots mrboots is offline
Vehicle: 2008 Dodge Ram 1500
Trim Level: Big Horn Edition
Color: Inferno Red
Rep:137
mrboots will become famous soon enoughmrboots will become famous soon enough
Did you have to do anything to the overhead compass screen before putting the roscolux over it? The reason I ask is because when I did it, it made the screen very dim and hard to see.
*edit* And just to be clear, I did disassemble the plastic and put the roscolux right on the screen, between it and the tinted plastic part.
2008 Dodge Ram
35% Tint, Flowmaster 40, Custom painted interior, Painted grill emblem, Custom CAI,6000k HID Fogs/6000k Grill lights, Custom bed LED's, Blue dash LED's, Engine bay/interior lighting, Custom audio, 4" Raptor Nerf Bars, Cooper Zeon LTZ's, Diablosport 93 oct. tune
Old 06-22-2011, 11:06 AM
Rep:4072
That looks awesome! Very nice write up and pics too, thanks for sharing!
Old 06-29-2011, 09:53 PM
Hosslt1's Avatar
Rep:114
No I'm having the same problem with mine and I really cant see the temp/dir during the day but it looks pretty sweet at night. Would love to know if you find a fix!
Old 07-06-2011, 09:15 AM
mrboots's Avatar
Color: Inferno Red
Rep:137
Yeah same to you. It's driving me nuts!
2008 Dodge Ram
Old 01-06-2013, 02:12 PM
wch911 wch911 is offline
Vehicle: 2007 Dodge Ram 1500
wch911 is on a distinguished road
Default Help Please
I have installed all the LED dash and over head console lights. I couldnt figure out why they were flickering and turning off untill I found this post. If I dont want to install the strip lights...Where do I need to install a load resistor?
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 09:19 PM
Switch back l.e.d's platinuminjected Custom Dodge Ram Interior and Exterior Lighting 21 02-26-2013 01:59 AM
Exterior Bulb Replacement Guide 300 Addict Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 3 08-20-2012 06:17 PM
interior lights in 98 ram 1500 lacamu Custom Dodge Ram Interior and Exterior Lighting 6 08-12-2011 03:43 PM
Dash light conversion help Hosslt1 Custom Dodge Ram Interior and Exterior Lighting 0 03-20-2011 12:45 PM
