Old 03-26-2011, 10:27 AM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 1998 Dodge Ram 1500 4x4
Trim Level: SLT Laramie quad cab
Color: red
Rep:52
98redbull2 will become famous soon enough
Originally Posted by The Machine View Post
the muffler has no cat on it and already checked the oil and oil screen it's fine no problems with that could it be an oil pump?
yes it could possibly but also could just be the sending unit thats falty, seen plenty of those..
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
Old 03-26-2011, 01:26 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Did you try changing the oil filter. If it collapsed, you could get these symptoms.
brad
Interested in one of my mods?
Old 03-26-2011, 01:28 PM
brad12kx's Avatar
Rep:2581
Originally Posted by al4171990 View Post
1997 dodge ram 1500 5.2 having major problems vehicle originally ran fine started having shifting problems while towing a trailer that weighed around 6000 pounds. Truck accelerates extremely slow slower than ever gets to about 2250 rpm in first gear and will not shift unless i let off gas completely vehicle would not go over 35 miles per hour no matter what the harder you push the gas the slower it goes feels like its shifting into 2 gears at the same time scanned CEL with cheap scanner got misfire codes on all cylinders replaced all plugs, wires, cap and rotor engine runs a little rough i know plug wires are on correct plugs changed them one at a time to avoid confusion tried driving today and it would not go over about 25 MPH then slowly would not maintain speed at all until it had absolutely no power it would lurch forward then stop then lurch forward and stop again repeating same thing over and over and even in park engine would not rev up over 1500 rpm any help is greatly appreciated sorry about the massive run-on sentence lol.
Thanks, Alex
Did you happen to check the trans oil level? If low (or high) it can create some pretty interesting loads on the engine, some of which can affect it even in Park.
brad
