Old 03-23-2011, 07:55 AM
JackDaniel's Avatar
JackDaniel JackDaniel is offline
Vehicle: 2005 Dodge Ram
Trim Level: Rumble Bee #897
Color: Yellow
Rep:101
JackDaniel will become famous soon enoughJackDaniel will become famous soon enough
Default Bad MPG with CAI?
Has anyone experienced worse gas mileage with the addition of a CAI? Im not 100% sure, but it seems like Im going through the gas like crazy, like I can literally watch my nujmbers drop on the meter till empty. Could be me and maybe its that Im not gettin the same amount of fuel I was before with the higher prices, but just curious if I missed something or something should be checked, thanks.
1970 Nova 402BB
1971 Nova parts car
2003 Harley Softail
2004 Ford Mustang GT
2005 Rumble Bee (for sale!!!!)
Old 03-23-2011, 08:15 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Is it possible your driving habits have changed, more foot in the go peddle cause it sounds great? On mine I went with a drop in this time as when I used a CAI on my 06 I seemed to want to hear it and miles dropped.
Old 03-23-2011, 09:47 AM
wylie wylie is offline
Vehicle: 2011 Dodge Laramie 1500 CC
Color: Blue
Rep:55
wylie will become famous soon enough
Did you put a new tune in the computer when you added the CAI? You have to tell it that it is getting more air so the computer can adjust. I suggest you take the CAI off and put the factory stuff back on and compare. It's a cheap start.
Old 03-23-2011, 10:31 AM
charlieb's Avatar
charlieb charlieb is offline
Vehicle: 2004 dodge ram 1500
Rep:31
charlieb is on a distinguished road
the new cia u added doesnt make the engine take in more air or change any mixtures or anything it just allows more free flowing cooler air into engine when it demands it (when u stomp on skinny peddle) not possible to make mpg worse when u are driving same as before.not sure if u are in the north but winter gas can have an effect on mpg.
Old 03-23-2011, 09:39 PM
xPUNlSH3Rx's Avatar
xPUNlSH3Rx xPUNlSH3Rx is offline
Trim Level: SLT AWD
Rep:38
xPUNlSH3Rx is on a distinguished road
Spectre CAI here and my mileage stayed the same and since I live on base I usually stay off the throttle, every now and then I step on it. But yes like Charlieb mentioned if you're up north like I am sort of (Hill AFB, Utah) they formulate the gas for the harsh winters. My MPG dropped like 3-4 just from this past summer
Performance: Flowmaster Super 44 Side Exit, MagnaFlow Y pipe and Spectre CAI
Audio: Pioneer AVH-P5200BT, MTX Thunder 6x9, JL 10" Sub, Audiostream BX-10 Bass processor, Jensen 500w Amp and Rockford Fosgate wiring
Old 03-24-2011, 03:11 PM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
Adding a CAI/Exhaust to your vehicle is going to increase the amount of air running through the engine. The ecu is going to take this as it needs to correct for the added air by introducing more fuel. This is why you will see a drop in mpgs. If you get a tuner the tune will make this correction more effective and you may see an increase in MPG's.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 03-24-2011, 03:35 PM
In addition to the advice offered above, which is all good info, check to make sure all your connections are tight and there are no intake leaks.
Also, how long has the intake been on?
Old 03-24-2011, 05:53 PM
Color: Blue
Rep:55
Thanks ramtex,,,any time you mess with air and fuel on these electronic controlled engines, you need to put a tune on it.
Old 03-24-2011, 06:15 PM
wester399's Avatar
wester399 wester399 is offline
Vehicle: 2006 Dodge Ram 1500
Rep:100
wester399 will become famous soon enoughwester399 will become famous soon enough
i havent noticed an increase or decrease seeing mine was installed during winter.
Old 03-24-2011, 08:54 PM
RamTex's Avatar
Color: Stone White
Rep:366
driving habits take a huge role in getting good mpgs also.
MPG / Wheel Size jokkling Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 41 01-09-2013 04:26 PM
180 degree thermostat = more mpg? polkat Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 6 03-19-2011 05:52 PM
Mod 2 CAI kap64 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 6 12-03-2010 07:34 PM
CAI bad for mpg? ramgearhead Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 9 08-09-2010 09:54 PM
Airaid CAI, 2.5 mpg better J Heavy Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 21 08-02-2010 11:02 PM
