Old 03-23-2011, 10:35 AM
Bighawk68 Bighawk68 is offline
Vehicle: 2010 Ram 1500 Lariat
Trim Level: Lariat
Bighawk68 is on a distinguished road
Default 2010 Ram will not shut off?
My 2010 Ram will not shut off by turning the key to the off position. I have to pull the key out for it to shut off.
Has anybody seen this? It's under warranty but I was wondering if there is a quick fix.
Thanks
Old 03-23-2011, 10:37 AM
Rep:1845
Never seen this problem but I would suspect a faulty WIN module.
Old 03-23-2011, 10:43 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Wow...this is not your normal every day problem. I've heard of people having trouble starting....but never shutting off. Definitely a job for the service department. keep us posted as to what they find.
brad
Interested in one of my mods?
Old 03-23-2011, 03:19 PM
testiclops's Avatar
testiclops testiclops is offline
testiclops is on a distinguished road
A truck that won't stop running? Sell this information to Ford.
"Please contact the Administrator if your date of birth has changed."
Old 03-23-2011, 03:21 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Hahahaha
I have no clue what's wrong, but I would bring it in and get it checked out.
Dillon-aka, The Little Kid
Old 03-23-2011, 07:57 PM
Btreat003's Avatar
Btreat003 Btreat003 is offline
Vehicle: 2010 Dodge Ram Sport Crew
Rep:26
Btreat003 is on a distinguished road
thats hilarious!!
Old 03-24-2011, 12:04 AM
JRI JRI is offline
Vehicle: 2010 Ram Crew Cab
Rep:14
JRI is on a distinguished road
Thanks
Just to be clear;
When you say it won't shut off do you mean that the engine is still running with the key in the off position?
The engine should stop running but the radio, etc will still play until the key is removed.
Old 12-30-2011, 08:05 PM
Rideron Rideron is offline
Vehicle: 2011 Ram 1500
Color: Dark Brown
Rideron is on a distinguished road
My 2011 just began doing the same thing. Key is turned off, removed from ignition, and the engine keeps running. It will turn off if I reinsert the key, turn to 'on' and return to 'off'. What did they do to fix yours?
Old 04-23-2012, 11:15 AM
jimjoe jimjoe is offline
Vehicle: 2009 Dodge Ram 1500
jimjoe is on a distinguished road
Default Any Updates???
Hi Guys! I'm new to the forum, but just last night had my 2009 Ram have the same situation. Put it in park, turn the key off, pull from the ignition, truck keeps running. What did the solution end up being for you guys? I had to pull the wiring harness from the ignition module to get the truck to shut down
Thanks so much for your help.
-jim
Old 04-26-2012, 12:38 PM
ArmyofOne's Avatar
US Army Retired
Rep:1189
HAHAHAHAHAHAHA I LOL'd so hard...
Still 'ing
THAT sounds like an ignition switch.
-jim
You guys all have several potential issues... my truck is 9,000 miles away, so bear with me.
-Bad ignition switch is a possibility.
-Key may have partially dropped its programming.
-if your battery in your key is going dead, but not dead yet, it will do this. I replaced my battery and my problem stopped.
-certain fuses and relays being bad will cause this also.
gives you a place to start anyway.
Diesel Technician-PACCAR Inc.
2010 Recall - K08 RamTech Dodge Ram Recalls and TSB's. 6 02-25-2011 04:13 PM
Chrysler Group LLC Reports July 2010 U.S. Sales Increased 5% UN4GTBL Automotive Industry News and Dodge Press Releases 1 08-04-2010 03:28 PM
DVD Player bseifert79 2010 Dodge Ram Forum 5 05-06-2010 08:26 PM
2010 vs 2007 ScatPak07 Dodge Ram General Discussion 20 03-12-2010 04:02 AM
