tonneaucovered.com
Old 04-12-2011, 12:04 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Same one for you JD, Freddie uses it in his 05!!!!
Old 04-12-2011, 12:07 PM
Wildcat's Avatar
Wildcat Wildcat is offline
Vehicle: 2010 Dodge Ram QC 4x4
Color: Mineral Gray Metallic
Rep:166
Wildcat has a spectacular aura aboutWildcat has a spectacular aura about
I have been doing a lot of research into this cheap mod, and I have come to the conclusion that I am going to stay away from it for several reasons. The first being that the computers in our trucks are programmed to run most efficiently around 200ish degrees, and running cooler can actually negatively impact fuel efficiency. Also, most motor oils are formulated to be run around 200 degrees and running cooler can actually reduce the oils lubricating properties. There is a widely held belief in many circles that this can actually prevent burnoff of carbon and other contaminants and lead to engine sludge. I know, running hotter can also negatively impact the oil, but from what I have read, this is most noticeable in vehicles running WOT, and in which cases, a larger radiator would have more reduction in temps than the thermostat.
Going to a lower temp thermostat is actually a very old school idea dating back to well before ECU's and modern engine building techniques. They were often swapped in during the summer and out in winter to help regulate the engines for varying seasons.
To each his own, I just wanted to encourage everyone to do a little more research into this if you are considering it. I hope I didn't spark a heated debate here.
Cobra CB, Dual antennas, Dodge molded splash guards, Tekonsha P2 brake controller, Weatherguard tool box, AirLift 1000 helpers springs, Line-X bedliner, B-Pillar tape removed, 35% tint front windows.
http://i842.photobucket.com/albums/zz347/kcwildcat1/Wildcatsig.jpg
Old 04-12-2011, 12:41 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
Should be the same p/n but the guy at the counter can cross reference for you. Anyone planning this mod can expect to knock it out in about 15 mins.
2 bolts hold on the tstat housing
A drain pan to catch any coolant
Swap the rubber gasket over to the new tstat
Reverse the procedures for install
Top off your coolant
After a day or so of driving check coolant level
Old 04-12-2011, 11:12 PM
jpaul51's Avatar
jpaul51 jpaul51 is offline
Vehicle: 2009 Ram 2500 Megacab
Rep:167
jpaul51 has a spectacular aura aboutjpaul51 has a spectacular aura about
I have the Jet 180* thermostat in my truck and love it. Letting the engine stay just a bit cooler seems to help keep the truck in its power zone. What I have noticed living here in Texas is that ( especially during summer months) when the truck has been running a while and the engine heatsoaks you can feel your truck losing power. Don't feel that with the 180*! no negative side effects during the winter either. Fuel mileage slightly better than with the factory 195*. Ok correct me if I am wrong on this.... In older cars the higher temps were used to burn off and prevent carbon build up. In modern cars and trucks detergent motor oils serve this same purpose. From what I have read you won't hurt anything unless you lower it all the way to 160*. if anyone is concerned about carbon build up then I highly recommend a treatment with Seafoam. I have used it and that stuff will blow that damn carbon right through your tail pipes! The 180* tstat is not a cure all but it sure does help!
2007 Ram 1500 QC - SOLD and bought a 2009 4x4 Megacab 2500 with 6.7 Cummins. Full Sinister EGR/Throttle Valve/dpf deletes, 4" Turbo back exhaust, Banks cold air intake, EFI Live tuning by Anarchy Diesel running 100hp Street tune. Peragon bed cover.
Old 04-24-2011, 12:16 AM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
i getting a code grr
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 04-24-2011, 09:53 AM
catsltd catsltd is offline
Vehicle: 2010 RCLB SLT 1500 Ram
Color: Mineral Gray
Rep:72
catsltd will become famous soon enough
Smile
If you use a cheap stat you might get a code.
If you use a Jet stat you wont.
There are a million reasons to change out the stock 203 degree stat.
Heres a few.
Before swap:
Engine temp 201.
Oil temp 204.
Oil pressure 29-PSI.
Intake air temp:118 degrees.
After:
Engine oil temp:183-185.
Oil temp:179 degrees. 25 degrees cooler.
Intake air 102 degrees.
Oil pressure:37PSI. 20% improvement.
I cannot find the transmission numbers but they were even more dramatic.
Benifits:
Less engine detonation great for towing.
For every 10% cooler intake air supposed to be good for 1% increase in hp.
Maybe only 3.9 hp gain but ill take it.
Better oil pressure what more do you need to say.
A cooler transmission what can i say.
Oil at 204 degrees is like boiling water.LOL.
It does not do a good job of removing engine heat,and it does not lubricate any better either.
I ran a 180 stat on my 2003 2500 Hemi ram for 7 years winter and summer,
towing a tandem dump trailer 5 days a week.I found no problems with this mod.
Anyone can use ther evic and they will get similar numbers,dont take my word for it.
2014-True Blue SLT,CC 6.4 BOX.
Air suspension,Rambox,Navigation.Backup camera.
3:92 gears.
Old 04-24-2011, 11:36 AM
Trim Level: st
Color: silver
Rep:68
i used jet still get code
Old 04-24-2011, 11:37 AM
Trim Level: st
Color: silver
Rep:68
i don't use cheap . i try to get another tune then. I don't know why i get it
Old 04-25-2011, 09:55 AM
Color: Mineral Gray
Rep:72
Its not from the thermostate then.
Whats the code???.
Nice setup by the way.
3:92 gears.
180 thermostat motorad
My DYI CAI just installed GPSHSLAX Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 70 07-15-2011 12:57 AM
Newly installed HID kits not working properly in two new Rams jwsnowman Custom Dodge Ram Interior and Exterior Lighting 16 02-01-2011 08:44 PM
Fender Flares Installed but a Question RansRAM Custom Dodge Ram Exterior Modifications - Body Mods - Body Kits 4 10-29-2010 04:14 PM
180 stat throws on check engine light? MoparMadness08 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 14 08-19-2010 07:22 AM
2010 RAM RT- K&N intake installed (pic) SPEEDFREAK 2010 Dodge Ram Forum 26 06-11-2010 07:20 AM
