Old 03-23-2011, 12:22 PM
babylacyjane babylacyjane is offline
Vehicle: 1997 Dodge Ram 1500 4X4
Color: Blue
babylacyjane is on a distinguished road
Default Wheel bearing failure?
The other day we had our wheel on our 97 Dodge 1500 come off the truck at 70 mph on the express way. No one hurt but, we had had the wheel bearing replaced about 10,000 miles ago. The shop that replaced it had given a lifetime warranty. He now claims that the disc brake inner pad only had rubbed on the rotor and caused the sealed bearing to over heat and fail thus he is not responsible for repairing it. I don't know how you could tell if the brake failed or the bearing failed 1st causing the brake to fail. Yes the router, caliper, wheel bearing, axial, brake line, and brake pads all were destroyed. Does anyone know where I might turn to learn how to tell and or the most likely cause?
Old 03-23-2011, 12:28 PM
Rep:1824
the only way I can see overheating being an issue is if the caliper was stuck, the hose collapsed internally, or a caliper guide seizing up causing the brake to stick. Got any pics of the damaged parts?
Old 03-23-2011, 01:38 PM
Color: Blue
No pics sorry,The pad that was on the inside of caliper was very burnt, Rotor showed signs of heat but I'm not sure if that didn't occur as the bearing failed and before wheel was ejected off the truck. outer pad showed normal wear. There was no noise from it and no pulling either until wheel came off.
Old 03-23-2011, 02:14 PM
Rep:1824
I still can't imagine how the bearing seperated if the axle nut was properly installed. Was the nut still in place on the axle shaft?
Old 03-23-2011, 05:34 PM
Color: Blue
no it was not here is a pic of axle with broken rotor in back ground
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 153 06-20-2014 10:56 PM
'05 Ram 1500 4x4 wheel bearing replacement daystrom Suspension 9 07-22-2011 09:10 PM
02 4x4 front wheel bearing replacement edgeracing Suspension 6 02-23-2011 10:00 PM
wheel bearing and clunk! Quiet Lunatic Suspension 6 12-25-2010 08:44 AM
Newbie with wheel bearing issues danielfochtman Newbie Checkin! 5 11-11-2009 08:37 AM
