clutch fan - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 5.7L V8 Specific Topics
Old 03-23-2011, 12:43 PM
charlieb's Avatar
charlieb charlieb is offline
Vehicle: 2017 ram express quad cab
Trim Level: express
Rep:37
charlieb is on a distinguished road
Default clutch fan
my hemi takes along time to warm up,about 15 mins before it blows warm air living in canada thats along time. i was thinking of adding a hotter t-stat but i noticed my clutch fan grabs less than 1 minute after starting and runs fairly constant.this will obviosly keep it running cooler and possibly lowering gas milage.anything i can look at to troubleshoot why it comes on when its cold.
Old 03-23-2011, 08:32 PM
Has your check engine light come on . If the computer sees that the engine has a problem getting to temp in a predetermined amount of time it will turn the light on . You could have a failing thermostat . When was the last time it had a good cooling system service ?
Old 03-24-2011, 05:24 PM
charlieb's Avatar
Trim Level: express
Rep:37
has 114,000km on vehicle no cooling system service yet.was waiting a bit coolant should be ok till 120,000km -150,000km.but the way my 5.7 chev clutch fan worked is clutch fan has copper or other alloy type spring grabber in it that when it heats up grabs shaft and engages (mechanical not electric) figured hemi should be same . so clutch fan should not grab shaft and start turning until it reaches certain temp (mechanical not electrical) but grabs pretty much read away after starting (within 1 minute of starting)my other clutch fans chev/ford grab after warm up 5-15mins not red away.when vehicle is off i can turn fan by hand (free spinning)
Old 03-24-2011, 05:33 PM
charlieb's Avatar
Trim Level: express
Rep:37
o yah no engine lights have ever come on except low wash so i just started washing her down low around her rear diiferential then moved my way up along her t case then on to her trans cover,cleaned up her oil pan then along her front differential all seamed pretty clean down low.then noticed i was out of the blue stuff under her hood topped her up and havnt had any engine lights since.but she still not warming up to me as fast as i want.
Old 03-24-2011, 07:52 PM
ICEMAN99TURBO's Avatar
ICEMAN99TURBO ICEMAN99TURBO is offline
Vehicle: 08 Ram
Trim Level: 1500 Big Horn
Color: Electric Blue Pearl
Rep:119
ICEMAN99TURBO will become famous soon enoughICEMAN99TURBO will become famous soon enough
Send a message via AIM to ICEMAN99TURBO Send a message via Yahoo to ICEMAN99TURBO
I wouldn't worry about it until your motor starts showing you that you are having an issue. Unless you are sure you just want a bigger fan to be cooler?
Don't park in the ditch, that's not where you park, you park in a parking lot! .... Stupid!
Old 03-26-2011, 08:24 PM
charlieb's Avatar
Trim Level: express
Rep:37
my basic point of my thread was my truck takes too long to warm up. iwas going to change t-stat but noticed clutch fan coming on early.therfore causing to stay cool b4 warming up.
Old 03-26-2011, 10:17 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
I don't think the fan operation has anything to do with that. Any extra cooling you get from the fan, will only affect the cooling efficiency of the radiator, and that doesn't come into play until the thermostat opens.
Tom suggested the possibility of a failing t-stat....I believe he is pointing in the right direction.
brad
Interested in one of my mods?
Old 03-27-2011, 12:17 PM
Resident Technician
Rep:1915
Changing the stat won't make the truck warm up any faster, it will only change the normal operating temp. Converting to a thermostatically controlled electric fan system might make some difference but I can tell you from my own personal experience that when I added a clutch fan to my electric only system, I didn't see a decrease in warm up times.
Old 03-27-2011, 09:05 PM
charlieb's Avatar
Trim Level: express
Rep:37
thanks ramtech just thought 15 mins warming to full temp was kinda long(thought clutch fan turning on right away had something to do with it) just gonna not worry about it and where my parka and long johns.
Old 03-28-2011, 08:59 AM
Resident Technician
Rep:1915
Just sitting and idling, that sounds about right to me. For driving down the road it would be a bit excessive unless the ambient temp is between bitter and OMG!
Fan and thermostat questions snrusnak Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 6 06-30-2011 04:54 PM
Replacing Water Pump (Question) How do I remove fan from waterpump pulley MMMMDude 5.9L V8 Specific Topics 6 01-31-2011 03:12 PM
Sticky fan clutch - still need clarity on this. Turbovsix 2010 Dodge Ram Forum 2 12-06-2010 01:12 PM
Fan Clutch Tech aftershokk86 5.2L V8 Specific Topics 4 11-06-2010 11:31 PM
1999 clutch problems imhedles Cummins Diesel Specific Topics 2 11-26-2008 02:32 AM
