Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Diablo Predator Questions & Info!
United Radio
Old 03-23-2011, 03:44 PM
RammD RammD is offline
Vehicle: 2010 RAM SLT REG. CABX2
Color: CRYSTAL BLACK PEARL
Rep:61
RammD will become famous soon enough
Default No Internal Power & Setting the Predator back to factory tune?
Fortunately this hasn't happened to me but it's a question i've wondered about for a while now and was bored so I figured i'd ask it. It's more out of paranoia then anything else but I have had vehicles that had electrical problems or alternator issues, etc, to where I not only couldn't start up but had little or no internal power either. Obviously a battery issue wouldn't count as a simple jump or battery booster would allow you to use your predator and reset the factory tune before having the vehicle serviced at the dealer.
So it just got me wondering if there were any way should our Rams have an issue where they lose internal power for whatever reason, i'm assuming we'd just be SOL in getting the factory tune reinstalled, right? Or would there be any other way to connect the predator to the OBD-II Port in a situation like this and get the factory tune reinstalled?
Old 03-23-2011, 03:46 PM
Rep:1824
If the PCM doesn't power up as it should, I'd say you're SOL.
Old 03-23-2011, 03:48 PM
MADDOG MADDOG is offline
Rep:22
Agree with that ^^^^! The PCM must power up and the Predator is not internally powered and gets its power from the truck interface.
Old 03-23-2011, 04:28 PM
Rep:61
thanks Magic Mike and Randy "The Post Ripper"...as usual you come through with prompt answers. That's pretty much what I figured but wouldn't of known if there were some work around unless I asked. I know the situation isn't likely, but it's far from improbable. With the fact that there's a predator out there for countless vehicles i'm sure this has actually happened to a number of people just by sheer numbers. Of course, there would have to be a series of negative events starting with that specific issue and followed by the dealer actually checking and seeing a tune other then stock is present, and then even more, showing how that would void the warranty for whatever the cause of the PCM issue was. So a series of events but one that I guess aren't impossible.
Randy, have you ever found a predator install on any vehicle you've ever worked on?
Old 03-23-2011, 04:34 PM
Rep:1824
I can't say I have but I figure this is for of two reasons. First, I just don't look for them. Second, we don't see many tuners on gas burners but we do on diesels.
Old 03-23-2011, 04:39 PM
Rep:22
"Magic Mike" ???? ROTFL....no magic here...no "Mike" either
How-To: Add Factory Fog Lights mjonesjr Dodge Ram Knowledge Base 13 11-24-2014 09:19 PM
air ram power wire 4doordodge4life Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 10 04-26-2010 11:37 AM
Setting the clock on the factory radio blackknight04 Custom Dodge Ram Interior Modifications - Custom Audio / Video 6 03-23-2010 08:26 AM
Won't Start!!! Please Help racer965 Electrical 13 01-21-2010 05:10 PM
