Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
MOPAR DECALS
Old 03-26-2011, 10:11 AM
GPSHSLAX's Avatar
GPSHSLAX GPSHSLAX is offline
Vehicle: 2009 Ram 1500
Trim Level: ST 2X4
Color: Bright Silver Metalic
Rep:236
GPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura about
Looks good. I would have recomended against painting the tubes before you cement them. If you use a pvc primer before the cement it will likely strip the paint, and if not it may not bond properly. I would also recomend a good plastic paint. It has a special formula to make it bond to plastic so it wont flake off under stress.
I did a very similar project last summer by the way.
http://www.ramforumz.com/showthread.php?t=57145
I never did figure out a way to rig up a bracket but it hasent hurt anything yet.
By the way, although this may be ignorant, of what power wire do you speak?
Mods: Thule Xsporter 422XT bed rack, Underrail Rhinolining, MOPAR class IV Hitch, DIY CAI, Aero Turbine 3030.
Future Mods/Wishlist: Tuner, Daystar Comfort Ride 1.5" Leveling kit, Nerf Bars, Police style push bumper with light guards, KC or Thule trail lights, HID projector lights.
Old 03-26-2011, 02:15 PM
RumbleRam's Avatar
RumbleRam RumbleRam is offline
Vehicle: 2002 Dodge Ram QCSB 4.7L
Color: Light Almond Pearl
Rep:30
RumbleRam is on a distinguished road
yeah, i havent cemented yet, i and i think im going to take the paint back off, i may try to do a black chrome to it, and you post is where i got my idea, i used what you did for your 4.7L but just a hair different lol, and the power wire, well all it is, is a relocator for my Intake Air Temp Sensor, on 2002's and maybe 2003's (idk) the IAT is in the intake manifold itself, on 2004-up it's moved just before the engine hat, and thats what im doing, im moving it to a colder posistion
Old 03-26-2011, 03:17 PM
GPSHSLAX's Avatar
Trim Level: ST 2X4
Rep:236
Ah, I see. That sounds like a good mod too. How are you planning to close the port in the manifold where the IAT used to be?
Old 03-26-2011, 03:35 PM
RumbleRam's Avatar
Rep:30
the web site where im getting the "power wire" also makes a plug for it, so i dont have to jam a threaded pipe in the hole lol
Old 08-15-2011, 09:10 PM
blake30615's Avatar
blake30615 blake30615 is offline
Vehicle: 2007 Dodge Ram 1500
Trim Level: Slt Thunder road
blake30615 is on a distinguished road
Call it the Sanford and son mobile
Old 08-16-2011, 10:49 AM
KRAZYK's Avatar
KRAZYK KRAZYK is offline
Vehicle: 2010 Dodge Ram 1500 CrewCab
Rep:92
KRAZYK will become famous soon enough
This is the first time I've seen this thread.. Nice work!
What sort of gains did you get?
SuperChips FlashPaq | 6000K HIDs Hi/Low | custom DIY intake | CherryBomb Glasspack | Daystar 2.5" Leveling Kit + Bilstein Shocks | 5% tint front and back | smoked tail lights and 3rd light | Pioneer AVH-P3200 2DIN + SIRIUS tuner | Reverse Camera | Kicker ZX700.5 | Kicker S10L5 sub in a FoxBox
Old 08-16-2011, 11:38 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1388
5 month old thread, guess he didn't do any dyno tests....?
Sean
Old 08-16-2011, 11:52 AM
bombadillo's Avatar
bombadillo bombadillo is offline
Vehicle: 2011 Dodge Ram 1500 4x4
Rep:25
bombadillo is on a distinguished road
When its all done, glued together with PVC glue or however you're doing it, you know what would make it look sweet is to wrap that bad boy in black header wrap.
Would cut down on a bit of the sound, but also keep the engine from heating up the air going through it too much. More of a functional gain than anything.
2011 4.7L with AVS ventshades, Vision 375 Warrior wheels, Daystar 2.5" leveling kit, GTS Blackout taillights. Magnaflow exhaust done custom, (sounds AWESOME) and I'm sure more to come.
Old 08-16-2011, 11:55 AM
snrusnak's Avatar
Rep:1388
_________________
I've always had the thought that the temperature of the pipe wasn't all that important, but the temperature of where the air is being drawn from is vital. The air will pass through the intake pipe very rapidly....so it won't have time to transfer heat from the pipe to the incoming air charge. Since the air charge is always moving (basically) it won't have time to heat up even if the pipe was several hundred degrees....
Sean
Old 08-16-2011, 02:55 PM
KRAZYK's Avatar
Rep:92
I would agree.. alot of CAIs you see are made with aluminum tubing even. This would mean that it would transfer even more heat then PVC tubing would. But I have the same take on it, I think the air is passing through and isnt really being effected by the temp of the tubing.
