Old 10-07-2011, 12:05 AM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
You are going to be sucking up hot engine air into that intake which will hurt performance. You need to get the air filter out of the engine bay or build a baffle box. All of those bends won't help you either.
Just so you know, You can heat & bend PVC pipe. Just take a propane torch, not a little hand held one but one that connects to a 30 lb tank. Slowly heat the entire pipe up & it will become pliable, then you can bend it & when it cools it will stay. That's how electricians bend PVC conduit. Then you can paint it & it won't have any elbows & will have a very clean look to it.
I agree about the hot air. You can't bend large diameter PVC though(easily). I've tried and was not successful. Largest I was able to successfully bend was 2", and it didn't look real pretty. When I tried 3" I didn't even get to a 45 deg bend and it ruptured the PVC. I had it packed with sand and heated the pipe evenly, it's just too sharp of a bend with the larger diameter...
Sean
Old 10-07-2011, 01:07 AM
RumbleRam's Avatar
RumbleRam RumbleRam is offline
Vehicle: 2002 Dodge Ram QCSB 4.7L
Color: Light Almond Pearl
Rep:30
RumbleRam is on a distinguished road
yeah i know i need to revise it but i did it in about a hr and all the parts where free except for the filter which, free PVC to build your own is hard to pass up
Old 10-07-2011, 04:48 PM
M n M M n M is offline
Trim Level: ST 1500 Quad Cab
Rep:79
M n M will become famous soon enough
I was a plumber for several years and never attempted to heat bend anything over 1 1/2 inches. Maybe you've got that figured out though
Old 10-07-2011, 04:49 PM
Rep:79
Did you ever get the sensor relocated?
Old 10-10-2011, 09:18 PM
RumbleRam's Avatar
Rep:30
waiting on it now actually lol
Old 10-12-2011, 10:03 PM
02BlackBetty4.7's Avatar
02BlackBetty4.7 02BlackBetty4.7 is offline
Vehicle: 2002 Dodge Ram 1500
Trim Level: SL
02BlackBetty4.7 is on a distinguished road
Originally Posted by bombadillo View Post
Not really. We use it on rat rods all the time for the look alone. Usually white and we try to "dinge" it up a bit and make it look good and used.
"The rats"
That place looks familiar. Where is it located?
Magnaflow Exhaust, K&N CAI, AFe 1" Throttle body spacer...
Old 10-13-2011, 05:46 PM
RumbleRam's Avatar
Rep:30
well i got my power wire, 180 t-stat and IAT plug i the other day, i plugged the power wire in first thing and noticed a difference instantly, im going to put the 180t-stat in probably this weekend and relocate my IAT with the power wire to a colder spot
Old 10-13-2011, 05:51 PM
snrusnak's Avatar
Rep:1385
Do you know what your truck runs in the 1/4?
What are the balanced injectors?
Sean
Old 10-14-2011, 07:35 PM
Gene K Gene K is offline
Vehicle: 2010 Ram 1500 Crew Cab 4x4
Gene K is on a distinguished road
You will find the air flow through the intake tube tends to cool it. My testing has shown a worse case of 20F above ambient at idle to 2F above ambient at full throttle.
Gene
