Old 03-23-2011, 10:41 PM
SolidRam's Avatar
SolidRam SolidRam is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Lone Star Edition
SolidRam is on a distinguished road
Default Fuel supply Problem
Okay so I seem to be having a problem with fuel getting to my engine. I'm wanting to check out the fuel filter first, the only problem is the fuel filter for a 2001 Dodge Ram 1500 5.9L V8 is built into a module sitting inside my gas tank. It seems to be a pain in the ass to replace a filter and everything in the module for damn close to 300 dollars. So I figured maybe I could bore out the fuel filter or just bypass it,cut the fuel line and put an inline fuel filter somewhere on the chassis, would fix my problem and if i ever had to replace it again I could very easily, just wondering what was anybody's thought on the subject or if you've had any experience with customizing a fuel filter set up.
Old 03-24-2011, 08:24 AM
Rep:1909
If you have a fuel pressure/volume test performed, it will tell you if you need to go into the tank or not.
Old 03-25-2011, 11:15 PM
It's not really a fuel filter . It's more less a strainer . The only time they should be replaced is when replacing the fuel pump . They don't get clogged up like everybody thinks they do .
Old 03-25-2011, 11:57 PM
SolidRam's Avatar
Yeah, I've replaced fuel filters on a few vehicles, some vehicles have a fuel sock instead of a filter or in conjuction with it, they do get clogged up from fuel being pressed against that screen, sediment fills on the center of the screen and from there things just get worse... and with the rising gas prices I can only imagine how horrible the quality of fuel will be, really dirty gas....
Thanks for ya'lls input, much appreciated
5.9, customize, filter, fuel, replace
error code list moparmike07 Dodge Ram Knowledge Base 16 02-15-2014 04:16 PM
SS/T Problems round 2 98sst Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 48 01-11-2010 07:54 PM
Truck has fuel supply problem goldhorse1 Dodge Ram Knowledge Base 1 01-11-2010 07:49 AM
Fuel fill problems RamTech Dodge Ram Knowledge Base 3 01-09-2010 10:38 AM
dtc po148 nachizzle Cummins Diesel Specific Topics 2 06-09-2009 12:36 PM
