Old 03-24-2011, 12:43 AM
gshank21 gshank21 is offline
Vehicle: 1994 Dodge Ram
Color: Orange
gshank21 is on a distinguished road
Default 1994 Dodge Ram Shaking at low RPM
I have a 1994 Ram
160k miles
A few months ago i started having problems. When the truck warms up the engine shakes violently at low RPMs. I've changed the spark plugs, spark plug wires, distributor cap, rotor, fuel pump, EGR valve, cleaned the injectors, replaced the injector seals, and had the engine decarbonized. I also did a compression test. All cylinders were in range but cylinders 2 and 3 were on the low side of normal. Everything i did helped for abt 2 hrs and then back to normal rough idle and violent shaking at low RPMs while in dirive. After i changed the EGR valve tonight the problem stops immediately when the over drive is turned off. I'm thinking the problem might be a clogged catilitic converter or a faulty O2 sensor. Any advice would be appriciated.
Old 03-24-2011, 08:27 AM
Rep:1909
A bad converter would cause even worse performance in higher RPM ranges. What were your compression numbers on each cylinder?
Old 03-24-2011, 02:10 PM
Color: Orange
The PSI on all but cylinders 3 and 4 was 160. 3 and 4 were both abt 140. O2 sensors were also checked today and are working correctly.
Old 03-29-2011, 12:22 PM
98redbull2's Avatar
98redbull2 98redbull2 is offline
Vehicle: 2014 RAM 1500 4x4 HEMI express
Trim Level: express blacktop
Rep:52
98redbull2 will become famous soon enough
could the harmonic balancer be causing a shake? when it warms up and drops down to that certain rpm that makes it out of balance?
the 5.2's are externally balanced arent they? im not sure i remember
REDBULL: Red 1998 Dodge Ram 1500 SLT Laramie, 5.2L
2009 TSBs BlueJet 2009 Dodge Ram Forum 38 10-28-2014 05:03 PM
1994 dodge ram check engine light- wont idle sometimes hillvalley 5.2L V8 Specific Topics 6 10-25-2011 10:35 PM
Dodge Ram K&N 1500 2500 3500 Ramrob Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 16 03-21-2010 11:50 AM
New to Dodge need help! 1994 2500 4x4 MichiganMadDog Newbie Checkin! 11 12-10-2009 11:12 AM
DODGE RAM vs ford f-series CHILLZ HEMI Dodge Ram General Discussion 59 11-01-2009 05:20 PM
