Old 03-24-2011, 03:37 AM
TRX4Hemi's Avatar
TRX4Hemi TRX4Hemi is offline
Vehicle: 2006 Dodge Ram 1500
Trim Level: TRX4 Off Road
Color: Gun Metal Gray
TRX4Hemi is on a distinguished road
Default Tire rub! Wheel Spacers? Or get new rims?
So, I have a Leveling kit already on my 06' TRX4. Currently running 35X12.50. I have the stock 17" rims. I am getting some tire rub on the A-Arms in the front when I turn the wheel. Question is, What size spacer do I need to get rid of this... or if a spacer is out of the question, What offset do I need if I buy a new set of rims?
Don't really want to down size in tires because they are new meats.
Thanks
Old 03-24-2011, 10:59 AM
RamTex's Avatar
RamTex RamTex is offline
Vehicle: 2009 Dodge Ram 6.6L Hemi!
Trim Level: Crew Cab Sport 4x4
Color: Stone White
Rep:366
RamTex is just really niceRamTex is just really niceRamTex is just really niceRamTex is just really nice
I would go with 1/4 spacers. But i would take it to a local shop and have them check it out they can test fit different sizes. I use 1/4in spacers on my truck.
"New Project" 1969 Road Runner
BV Heads,K1 Crank and Rods,Corrillo Pistons,ARP Head, Main, Side Studs and Rod Bolts,Spartan Eagle Cam,6.1 Manifold,Fastman 85mm,LMI Hammer, ARH's,3000TC,Hemifever Tuning
Old 03-24-2011, 07:37 PM
TRX4Hemi's Avatar
OK, Thanks for the response. Do you have a lift or leveling kit? and what size tires? I put 1/4" spacers on the front--> No rub w/ Procomp mud terrains that are almost worn out, But rubs even worse with my new Wrangler MT/R's w/ Kevlar. I'm super bummed because the wranglers are brand new and don't want to have to buy new tires. So as of now i'm running the MT/R's on the rear and Mud Terrain's on the front to avoid the rub issue. (Both 35X12.50) Any other suggestions?
Old 03-24-2011, 07:39 PM
ScatPak07's Avatar
Rep:970
Really the best thing you can do if you have the money is go with some aftermarket rims! The spacers (I HAVE HEARD) can cause problems, some guys say stay clear of them. I personally am getting spacers for my truck as well, but I have rims also. The say it can cause damage to the wheel bearings by wearing them out quicker. I dont know if this is totally true though. It is a controversy thing that will always butt heads. If you do get a spacer then go with either 1/4" or 1/2". You should really know how much you need by looking at how close the tires are to rubbing.
If you go with rims then you should look at an offset of between -10 & -20mm. The best thing about gettig rims is that it makes the truck look different and custom. When I threw rims on my truck it took it to the next level. That would be the best way to fix the tire rubbing issue.
Old 03-24-2011, 08:48 PM
TRX4Hemi's Avatar
Yeah, I was hoping i wouldn't have to pony up the cash for new rims, but I think your right scatpack. The farther out your tire is mounted, the more stress it's gonna put on your bearings. I would like to stick with 17's but will go as big as 20". Any other suggestions out there for backspacing and offset to clear 35's???
Old 03-24-2011, 09:20 PM
GeauxHunting's Avatar
Vehicle: 2005 Dodge Ram 1500
Rep:1338
Yeah, spacers would be the cheap route, but like Scat said rims give your truck a new sweet luck. I would suggest a -12mm offset if you get new wheels.
Dillon-aka, The Little Kid
Old 03-25-2011, 03:59 AM
TRX4Hemi's Avatar
Thanks guys, I think i'm going with new rims. I'll post pics if I ever decide on a set.
Old 03-25-2011, 08:19 AM
moparmanicac's Avatar
moparmanicac moparmanicac is offline
Find em hot leave em wet
Vehicle: 12 RAM 1500 qc 4x4 HEMI
Trim Level: express
Color: bright silver
Rep:204
moparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura aboutmoparmanicac has a spectacular aura about
I have also seen wheel spacers cause problems if you wheel/run your truck hard at all if you have the money id get some sweet aftermarket wheels w/ a negative offset
[SIGPIC] RIP 02 4.7 Dakota sport qc 4x4
RIP 05 Ram 4.7 rc 4x4
HELLO 12 Ram HEMI qc 4x4 and 94XJ
Old 03-25-2011, 09:53 PM
ScatPak07's Avatar
Rep:970
If you do go with rims then you should look at a -18mm offset. I have a set of Moto Metal 951 rims and they have a -18mm offset and a 4.8 backspacing. I have 14.5" wide tires on right now and they still clear. They come very close so I am getting a small spacer just to make it more comfortable.
Old 03-27-2011, 03:00 PM
TRX4Hemi's Avatar
I'm only lookin for as much as maybe 13" wide, so... -12mm should be alright??? By the way, Scat, your truck looks badass! It gives me confidence that your fitting 14.50s under yours
leveling kit, offset, tire rub, trx4
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 160 05-19-2015 09:42 PM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 04:29 AM
Wheel hop! sprintertech Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 14 02-06-2011 10:40 PM
All four rims damaged at Fountain Tire jimbodean Dodge Ram Wheels And Tires 71 10-07-2010 06:44 PM
Wheel Spacers causing severe Wheel Wobble nantuzzi Dodge Ram Wheels And Tires 3 06-10-2010 10:17 PM
