Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 03-24-2011, 09:48 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Here is a link to everything you every wanted to know, and were not afraid to ask about the 2001 Dodge Ram heating and Air Conditioning system.
brad
Interested in one of my mods?
Old 03-24-2011, 09:51 AM
Rep:1909
Yes, you can go with a lower stat. No, the PCm doesn't need any programming. The dash has to come out to access the blend door. I'd try a back flush and stat before I went after the blend door unless you know for a fact there's a problem with it.
015.2Ram 015.2Ram is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: XLT
015.2Ram is on a distinguished road
If it were a blend door issue would that not affect the AC also which is blowing cold?
Old 03-24-2011, 09:52 AM
Trim Level: XLT
PULL the dash. GOOD GOD. ha ha ha ha. I will hit on the other basics first.
I assume I can run a 160 thermo in this and it be ok?
Trim Level: XLT
when you get into the rad system and when filled back up does the system need to be bleed or anything?
Old 03-24-2011, 09:56 AM
Rep:1909
No, don't go that low with the start or you'll set a rationality code in the PCM. Stick with 185F or above.
Old 03-24-2011, 10:28 AM
Trim Level: XLT
WHAT IS THE FLUSH PROCEDURE ON THIS TRUCK? DO I HAVE TO BLEED IT WHEN FULL OR JUST CLOSE IT UP AND BE ON MY WAY?
tHANKS
Old 03-24-2011, 11:01 AM
Trim Level: XLT
Did these 01's come with the orange dexcool in them? Mine has it, that orange colored stuff. Should i stick with it or go green?
Sorry i am in caps, my work systems work in caps only and i forget top change it. I am not shouting.
Old 03-24-2011, 11:22 AM
Rep:1909
You'll need to obtain and install a flush kit from a parts store. Stick with the original type coolant.
Old 03-24-2011, 11:42 AM
Trim Level: XLT
What is the orig coolant for this truck??
having a little heater issue, ( PLEASE HELP ) mark1963 Dodge Ram General Discussion 0 12-18-2010 11:31 PM
Heater / Air Conditioner Control turbomir Heating & Cooling 2 12-04-2010 12:54 PM
Heater quit working right when it gets cold! danielstarr Heating & Cooling 3 12-02-2010 02:25 AM
Factory Engine Block Heater / Remote Start 10ramisport 2010 Dodge Ram Forum 17 10-18-2010 10:15 AM
Big Bang after heater core job Quiet Lunatic 5.9L V8 Specific Topics 5 12-31-2009 06:19 PM
