Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 03-24-2011, 12:53 PM
Resident Technician
Rep:1909
Glycol base coolant with corrosion inhibitors called HOAT, (Hybrid Organic Additive Technology) is recommended.
Old 03-24-2011, 01:46 PM
015.2Ram 015.2Ram is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: XLT
015.2Ram is on a distinguished road
So if I walk up to my local PEP BOYS dude, and throw those terms at him he will know what I need? ha ha ha. I have never heard it put that way. Orange or Green colored is what I have always went by. Ha ha ha
Thanks for the help folks.
Old 03-24-2011, 02:21 PM
Resident Technician
Rep:1909
Depends on how well the Pep boy knows his job.
Old 03-24-2011, 03:56 PM
Trim Level: XLT
Weeeeeell on lunch I drove it home and it heated up pretty much fine. This truck has not been used much at all in recent months. I wonder if the blend door was stuck or just slow to work correctly. When I got in it for lunch and drove home it warmed uo better. The fill tank, overflow? was between low and full, so I did top that off to full. She is very warm not. Maybe it jsut needed its legs worked out a little so to speak.
The temp gauge also runs with the needle riding JUST at the top of the front/left side of the 2 of the 210 on the gauge.
Old 03-24-2011, 03:59 PM
Trim Level: XLT
I did notice that most all of the rad was hot but the side at the fill cap was cooler then 75% of the rad to the touch. Looking down at top of rad on that left side (pass) you do see a break in the rad, a seam there. I guess that is made diff onthat side near the cap???? That 1/3 of the rad was cooler then the rest of the rad when I was stopped at home, looking into the intake for oil to see if that intake/plenum gasket was bad. NO OIL.
Old 03-24-2011, 04:27 PM
Resident Technician
Rep:1909
Sounds like it could be the core partially clogged and it may be working its way through the system. I'd still flush it out.
Old 03-24-2011, 04:28 PM
Rep:2705
if you look at a couple youtube videos, they can give you a general idea of how some people attempt to fix their vehicles give you some suggestions
one guy says to take the heater hoses off near the water pump, instead of back against the firewall where there is really no room to move your hands or tools
most input heater hoses have a heater control valve in the line, most have a cable that opens & closes them, make sure it opens & closes
when you back flush the heater core, use safety glasses, & either air pressure or a garden hose, use only enough water pressure to see if you have any flow, catch the old fluid & gunk in a gallon milk jug or something that you can see into from the side
these vids are very informative
http://www.heatertreater.net/?gclid=...FQQ-bAodDCu_bQ
Old 03-24-2011, 04:42 PM
Trim Level: XLT
WHEN THE WEATHER GETS BACK TO 70 HERE IN cINCY i WILL WORK ON FLUSHING. THANKS GUYS!!!
Old 10-30-2011, 05:25 PM
Trim Level: XLT
Well I got to flushing it today. I did the heater core first, took hose off at the drivers side and at the pass side. It went CLEAR WATER rather quickly. It was dirty at first, not bad at that, then flowed clean water after that. I drained the rad. ran water through it, it was fine. Pushed the water through the pump, it was clean quickly.
So I refilled the system and I am still getting luke warm air at idle when it is at running temp. Once the truck is driving it warms up well.
At idle, running temp left side and right side heater hoses are HOT to the touch. The drivers side rad hose is hot, left side of rad is hot gets colder as you move to the right side of the rad and that lower hose on the pass side it cool.
Seems the blend door is working, when the heat is blowing how or even warm when I turn it to COLD the air goes COLD. This summer when the AC was used it worked fine, on cold it was cold, when it was changed to hot it warmed up.
Soooooooo?
Old 11-01-2011, 03:55 PM
BroncoLee BroncoLee is offline
Vehicle: 1996 Dodge Ram 1500
BroncoLee is on a distinguished road
Have you checked the function of the blend door? It's easy to check. I made a little video by the way if you want to look at it. There's a pivot point for the blend door you can easily see just by looking under the bottom of the HVAC tubing, I hooked channel locks to mine so you can see it and mine was actually blocked a little I helped it close and think this may fix my problem but I can't tell as it's warm today. I'll know Friday or so though...
Link:
HTH,
Lee
having a little heater issue, ( PLEASE HELP ) mark1963 Dodge Ram General Discussion 0 12-19-2010 12:31 AM
Heater / Air Conditioner Control turbomir Heating & Cooling 2 12-04-2010 01:54 PM
Heater quit working right when it gets cold! danielstarr Heating & Cooling 3 12-02-2010 03:25 AM
Factory Engine Block Heater / Remote Start 10ramisport 2010 Dodge Ram Forum 17 10-18-2010 11:15 AM
Big Bang after heater core job Quiet Lunatic 5.9L V8 Specific Topics 5 12-31-2009 07:19 PM
