Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 2nd Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 11-04-2011, 08:43 PM
xnumnutsx xnumnutsx is offline
Vehicle: 1995 Dodge Ram 4x4
Trim Level: SLT laramine
Color: inferno red
xnumnutsx is on a distinguished road
Originally Posted by BroncoLee View Post
Have you checked the function of the blend door? It's easy to check. I made a little video by the way if you want to look at it. There's a pivot point for the blend door you can easily see just by looking under the bottom of the HVAC tubing, I hooked channel locks to mine so you can see it and mine was actually blocked a little I helped it close and think this may fix my problem but I can't tell as it's warm today. I'll know Friday or so though...
Link:
HTH,
Lee
did this fix your problem? i have the same problem with my 95 1500. my heat gets warm but not hot. i even tried to put some cardboard in front of my radiator to try and make it a little hotter. i had it running at 220 deg. and its still warm.
Old 11-05-2011, 09:44 PM
015.2Ram 015.2Ram is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: XLT
015.2Ram is on a distinguished road
Sorry guys, I am back. I will check out this blend door thing.
As for the system I have flushed it all, put in a new factory tstat, bleed the system over several days. Seems the heat is some beter now BUT it is warm the last few days so really can't tell.
Old 11-06-2011, 04:52 PM
Trim Level: XLT
well I looked the shaft that spins back and forth as you change the temp from cold to hot, hot to cold. It is rotating as you change the temp. I put the fan on low and got up close to the unit and could her the door ot what ever is in there hitting a stopping point at the coldest and warmest seleted temp. Seems to me the door is operating correctly.
The truck heat is warming up much better, but still seems to cool off a little when I am sitting still. I do note when it is sitting still that if I turn the fan speed down the air get hotter. I wonder if the fan on high is pulling the blend door thingy closed a little?
Non the less, until we get some COLD weather back here in Cincy I can't really tell how it is heating at a sit still.
Old 11-07-2011, 05:45 PM
BroncoLee BroncoLee is offline
Vehicle: 1996 Dodge Ram 1500
BroncoLee is on a distinguished road
My blend door sounds and looks to be working fine but it's still not blowing very hot air. I'll try to flush mine out soon and repost if it works or not. It's in the 80s here right now so will be hard to test it...
Old 11-08-2011, 09:55 PM
Trim Level: XLT
Well all appears good to go now, FINALLY. Thanks for all the input in this matter.
Old 11-08-2011, 09:56 PM
Trim Level: XLT
I think it was the air in the system
Trim Level: XLT
took several days to burb it out and it finally got hot.
Old 11-09-2011, 01:51 PM
Good to hear yours is working better. I flushed out my heater core and mine seems to be working better so far. I just unhooked the hoses and blew it out with a water hose back and forth several times. It seems to be getting warmer now. SO, if your air blend door is working I'd suggest to anyone to remove the hoses and flush out the heater core back in both directions.
Old 11-09-2011, 07:39 PM
Color: inferno red
i will be flushing my coolant system and core tmrw. hopefully this fixes my heat problem!
having a little heater issue, ( PLEASE HELP ) mark1963 Dodge Ram General Discussion 0 12-19-2010 12:31 AM
Heater / Air Conditioner Control turbomir Heating & Cooling 2 12-04-2010 01:54 PM
Heater quit working right when it gets cold! danielstarr Heating & Cooling 3 12-02-2010 03:25 AM
Factory Engine Block Heater / Remote Start 10ramisport 2010 Dodge Ram Forum 17 10-18-2010 11:15 AM
Big Bang after heater core job Quiet Lunatic 5.9L V8 Specific Topics 5 12-31-2009 07:19 PM
