Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
Dodge Ram Decals
Old 03-24-2011, 01:17 PM
2008BIGHORN 2008BIGHORN is offline
Vehicle: 2008 Dodge Ram 1500
Color: Blue
2008BIGHORN is on a distinguished road
Default Spark Plugs??
How you guys doing, names Matt im new here, and i have a quick question about spark plus. The service manual says there are 2 different types of plugs in the engine for a total of 16 plugs, i belive it says to use regular cooper plugs for the top row and iridium plugs for the bottom row. My question is, would it be ok to use iridium plugs all the way around, or do i have to use 2 different types of plugs? Thanks for your time -Matt
Old 03-24-2011, 01:20 PM
Resident Technician
Rep:1915
Yes, you can use iridiums in the top row if you wish.
Old 03-24-2011, 06:08 PM
Color: Blue
cool thank you. next question, are the plugs the same, heat range wise? I pulled them out to check them they look the same length, so heat range is the only other thing im worried about, all the parts stores ive been talking to only have one listing, and when i tell them theres 16 plugs they just look at me like cows in a field.
Old 03-25-2011, 09:39 AM
Resident Technician
Rep:1915
As far as I knw they are. The only reason iridium is used in the bottom is because they're kind of a pain to get to, so they installed them to lessen the number of plug changes required.
Old 03-25-2011, 07:53 PM
BCWhite BCWhite is offline
Vehicle: 2003 Dodge Ram ST 4.7L V8
Rep:14
BCWhite is on a distinguished road
Im friggin scared to even touch mine. I changed plugs before, but it took me a minute to even figure out where mine are. Then they each have their own coil? I haven't even checked them yet because of this.
Old 03-26-2011, 01:14 AM
05atlanticblue's Avatar
05atlanticblue 05atlanticblue is offline
Vehicle: 2005 dodge ram
Trim Level: sxt
Color: atlantic blue
Rep:197
05atlanticblue has a spectacular aura about05atlanticblue has a spectacular aura about
in a pre-08 4.7 they are easy. especially if you have a cold air intake and already removed the resonator box.
remove the harness to the coil, take the 10mm nut off and pull the coil straight up. then drop a spark plug socket ona long extension..
changed the plugs in my dad's truck last weekend, it didn't even take an hour.
Old 03-26-2011, 04:38 PM
RamJamz's Avatar
RamJamz RamJamz is offline
Color: Austin Tan
Rep:23
RamJamz is on a distinguished road
Yea the older pre 08 4.7 was the easiest motor I've ever changed plugs on, straight up and down. Don't forget to put some anti seize on the plugs since the heads are aluminum also when you remove the coil use some compressed air to blow the hole out before removing the plug.
Lonnie
Flowmaster 40, Mopar Polished SS Exhaust Tip, K&N Drop/In.
Old 03-26-2011, 07:06 PM
RumbleRam's Avatar
RumbleRam RumbleRam is offline
Vehicle: 2002 Dodge Ram QCSB 4.7L
Color: Light Almond Pearl
Rep:30
RumbleRam is on a distinguished road
ehhh idk i really wouldnt put anti-seize on the plugs with aluminum heads...aluminum can strip pretty easy and adding anti-seize i think would just make it want to slip eaiser....but if you've never had any trouble got for it....i've just been burned with anti-seize on aluminum heads...but they are very easy to get to, just make sure if you unplug anything plug it back in!
Old 03-26-2011, 10:33 PM
Rep:14
Ima look into it. Just been browsing plugs and haven't decided which I want. The NGK Iridiums are intriguing.
Old 03-26-2011, 11:10 PM
Rep:14
Think I'm going to O'reilly's tomorrow to get the Champion 439's. They are OE compatable.
http://www.oreillyauto.com/site/c/de...3435&ppt=C0334
New Spark Plugs flndrpndr23 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 25 08-10-2013 08:32 PM
Did I not get the memo about spark plugs? Rusty Nib 5.7L V8 Specific Topics 15 04-08-2011 11:32 PM
8 spark plugs vs. 16 spark plugs Basic Corpse Newbie Checkin! 16 01-04-2011 11:23 PM
Replace Spark Plugs Every 30,000 Miles? cole3986 2010 Dodge Ram Forum 21 09-16-2010 08:00 PM
how to install spark plugs and remove them moparmike07 Dodge Ram Knowledge Base 24 07-06-2010 09:42 AM
