Old 03-28-2011, 05:37 PM
bigdaddyII's Avatar
bigdaddyII bigdaddyII is offline
Vehicle: 2012 Ford F-150
Trim Level: XLT
Color: Metallic Blue
Rep:91
bigdaddyII will become famous soon enough
I didn't downgrade. The tires I went back with are P285/70/17 Nitto Terra Grapplers. The load rating is 117. My original post was about the max PSI on the tire being the same as the suggestion on the door placard, and my concern about running them at max all the time. As stated in my previous post, I checked out the load ratings before I bought them in regards to reading opinions about P rated tires not belonging on a truck etc. Turns out that these have higher load ratings then what would have came stock and I have never had trouble with the 265s. My blackberry doesn't have flash so I can't post the link right now but Nittos site has all the specs of the tire.
Sure it'll suck, but it'll make you a man
Old 03-28-2011, 06:05 PM
latitud's Avatar
latitud latitud is offline
Color: Deep Water Pearl
Rep:78
latitud will become famous soon enough
The door placard would only give you information for the tire listed on the placard. since you are upsizing to P285/70R17, the door placard no longer applies and neither does the tire supplement guide. So you can run the MAX pressure listed on the sidewalls and be able to get the load carrying capacity listed on the sidewall.
Otherwise, here you go, hope this helps:
35 psi - 2833 lbs
32 - 2745
29 - 2623
26 - 2480
'P' rated tires are fine on pickup trucks; LT are more for 3/4 ton.
2010 Dodge Ram, 5.7 Hemi, Crew Cab
Old 03-28-2011, 06:15 PM
bigdaddyII's Avatar
Trim Level: XLT
Rep:91
35 psi - 2833 lbs
32 - 2745
29 - 2623
26 - 2480
Thank you sir!!! THIS, this is what I have been chasing and looking at th end of a rainbow for going on 2 weeks now.
Old 03-28-2011, 06:45 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
glad you figured out your problem there bud
Official Off-Road tire thread!!!! RamCountry Dodge Ram Wheels And Tires 96 01-16-2016 08:50 AM
Suspension, Tire, and Wheel Guide 57Hemi08 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 164 12-04-2015 11:58 AM
Tire Pressure Monitoring System Explained RamTech Dodge Ram Knowledge Base 4 03-14-2011 05:29 AM
Opinions needed for tire and lift additions... lots of reading haha ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 42 02-09-2011 11:25 PM
Question about my spare tire YoMoma Dodge Ram Wheels And Tires 7 04-07-2010 02:43 PM
