Old 03-25-2011, 09:02 AM
polkat polkat is offline
Vehicle: 2014 3500 mega cab cummins 4X4
Trim Level: Larimie
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
polkat is on a distinguished road
Question condensation freezing IAC on TB?
I was wondering if anyone else has encoutered this problem? I have the airraid CAI and have been getting condensation inside the tube and freezing the IAC during the winter. This in turn causes the engine not to start at idle, but will run when the i have the pedel pressed down and the rpm's at about 1K, whenever I let off the throttle the engine dies. What i did for a quick fix is to disconnect the vacuum tube that runs into the side of the modular tube right before the TB and haven't had a problem with it since. Is there any drawbacks to doing this. I know that there has been a TSB that was put out on this, called local dealership and they want $220 to fix it according to the TSB was wondering anyone has this problem and fixed it themselves? According to the TSB you have to get a new oil fill reservoir and relocate the PCV vavle to the back drivers side of the engine. Any advice would help! Thanks
Old 03-25-2011, 09:17 AM
Rep:1885
You got a TSB number for this? I've not heard of it and it didn't come up under my TSB list. You need to install some sort of filter in the line you disconnected or you'll be drawing dirty air into your engine.
Old 03-25-2011, 09:59 AM
Trim Level: Larimie
I found this TSB on a website called Genos garage, the TSB is 25-001-06, just did a goolge search for "dodge truck TSB"
Old 03-25-2011, 10:06 AM
Rep:1885
Ah, I found it now. They filed it in a different section than the one where I would have expected to find it (big shocker). I'm guessing we just don't get anough cold weather here for this to be an issue and that's why I haven't seen it. Thanks for the TSB number.
Old 03-25-2011, 10:16 AM
Trim Level: Larimie
I guess the TSB 25-001-06 was superseded by TSB 25-001-08 dated May 9, 2008
Old 03-25-2011, 10:17 AM
Trim Level: Larimie
i also found at this website as well.
http://www.wkjeeps.com/tsb/tsb_wk_2500208.pdf
Old 03-25-2011, 10:24 AM
Trim Level: Larimie
sorry the superseded TSB was supposed to be 25-002-08 not 25-001-08
Old 03-25-2011, 10:26 AM
Rep:1885
25-002-08, but yeah, it's been superseded. You could always purchase the parts and do the work yourself if you want to save a few bucks.
Old 03-25-2011, 10:41 AM
Trim Level: Larimie
Guess i would have to contact the dealship to get the prices? I wouldnt think that it would be that much.
Old 03-27-2011, 12:28 AM
canoeman16 canoeman16 is offline
Vehicle: 2002 Dodge Ram 1500 SLT 4x4
Rep:12
canoeman16 is on a distinguished road
Default Freezing in the TB
I also had this problem. Installed the TSB kit myself and my problem went away.
Windsheild Washer Fluid Freezing? Quiet Lunatic Body & Interior 6 03-24-2011 04:34 PM
Headlight Condensation dustin72 2010 Dodge Ram Forum 19 02-23-2011 10:39 PM
Back-up Camera when Freezing? RootBeer Dodge Ram General Discussion 7 01-07-2011 01:42 PM
Oil Sludge ( Condensation ) in 2003 4.7 OUbubba 4.7L PowerTech V8 Specific Topics 3 03-29-2010 07:48 PM
Condensation eecheek Dodge Ram General Discussion 1 07-14-2009 08:37 AM
