tonneaucovered.com
Old 03-25-2011, 04:05 PM
E220 E220 is offline
Vehicle: 2011 Dodge Ram 1500
Rep:82
E220 will become famous soon enough
Default Cold air intake info please
HEY GUYS I MIGHT GET A COLD AIR INTAKE FROM DODGE ,
A) WOULD THIS VOID WARRANTY
B) WHAT DOES ALL THIS MEAN
Disadvantages OF COLD AIR INTAKE
  • Hydrolock - The intake opening is lower to the ground than a standard air box, and more likely to introduce water into the engine when fording streams or flooded roads. Hydrolock generally does not occur unless the filter is fully submerged in water."Bypass filters" can be purchased which prevent most water from entering the engine. Some people use hydro shields to prevent this from occurring, however hydro shields are not completely water proof if the intake tube is completely submerged in water.
Old 03-25-2011, 04:09 PM
If you get it from Dodge then your warranty is intact.
Hydrolock is sucking water into the engine and cylinders. The engine cannot compress water and the engine locks up. That's gonna result in a lot of bendage in the rotating assembly, specifically the rods with associated piston and main bearing damage.
Old 03-25-2011, 04:25 PM
Rep:82
so if i get this from dodge are they going to be able to let this not happen ?
Because I was reading and it said cold air intake often causes hydrolock
Old 03-25-2011, 04:45 PM
916Timmy's Avatar
916Timmy 916Timmy is offline
Trim Level: SLT Big Horn
Rep:1443
Those are on honda style intakes, the ones that run under the bumper. You shouldn't have any worries of hydro lock on the Ram
Old 03-25-2011, 05:33 PM
Rep:82
Do cold air intakes have any ill effect on the engine like working it to hard and maybe putting more drain on the truck
Old 03-25-2011, 05:58 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
there are many upon many threads on intakes so just go to the search button and try that way then you can browse alot of different threads
Old 03-25-2011, 10:40 PM
RedDodge's Avatar
RedDodge RedDodge is offline
Vehicle: 2014 Dodge Ram
Color: Granite
Rep:25
RedDodge is on a distinguished road
I don't want to be a spoil sport..but unless you have an exhaust system to compliment the CAI, your really not going to see any advantage...I know some will disagree but in reality you can get a "drop in" K&N filter and get almost the same performance advantage. You won't get that growl that a CAI will give you but the cost is about $250 less.
Steve
www.monteman.com
Mods: Tinted front windows, UnderCover tonneau bed cover, step rails, bed mat, cabin air filter, 4 corner mud flaps, slush mats, drop in K&N filter.
Old 03-26-2011, 12:42 AM
916Timmy's Avatar
Rep:1443
I am gonna disagree a little here. CAI won't add a ton of horsepower, but a drop in is almost none. So I guess not much difference. They do work well with all the other mods that support airflow! But 10-15 hp on a dyno is pretty good compared to 3-4 for a filter change.
Old 03-26-2011, 09:52 AM
Skillets's Avatar
Skillets Skillets is offline
Vehicle: 2011 Dodge 1500 Big Horn Hemi
Color: Dark Cherry Red
Rep:12
Skillets is on a distinguished road
when every you say change your exhaust. do you mean headers and a different muffler, or just a different muffler?
Old 03-26-2011, 03:16 PM
Greg50Lt's Avatar
Greg50Lt Greg50Lt is offline
Vehicle: 2011 Ram 1500 Quad Cab 4x4
Trim Level: Sprot
Rep:20
Greg50Lt is on a distinguished road
My civic made power with just an intake on it. WHen I added intake header exhaust and tune I made 225whp stock the car made 180whp. Car ran high 13's with street tires.
AFter the long speel I just gave the point was that with just an itake your going to make more power. You wont see full benfits but youll see a gain. The factory intake tube has ribbs and the filter isnt as free flowing as an aftermarket one. So by changeing the intake tube to a smooth one and possibly wrapping it will help with smoother air flowing into the tb and IM and then wrapping it will bring even cooler air into the motor.
OE: Nav/Alpine, Backup cam, brake controller, side steps Aftermarket:Bedliner, Tonnopro bed cover, Windows 20% Tails and Cab light tinted, 18in Magnaflow, Black Fuel Hostage 20x9 trail Grapplers 295-60R20, TGC 2.5 front spacer .75 rear, Billet fuel door
Cold air intake Gossage55 Custom Dodge Ram Performance Mods - Engine - 5.2 Liter V8 11 04-10-2011 10:31 PM
Dirt road + Dust + Cold Air Intake tocou Dodge Ram 4x4 - Offroad Discussion 7 02-02-2011 03:49 PM
2009+ Hemi Ram MOPAR cold air intake chithead Dodge Ram Parts and Accessories for Sale - Trade - Want To Buy! 9 02-01-2011 10:10 PM
Question about cold air intake exomega Dodge Ram General Discussion 12 08-29-2010 04:53 PM
cold air intake rbarufaldi Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 3 05-27-2009 02:53 AM
