Old 03-25-2011, 07:50 PM
Jersey Ram Jersey Ram is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: none
Engine: 1996-1998 359ci (5.9L) Cummins 12-valve Diesel I6 215hp 440lb/ft(manual), 180hp 420lb/ft(auto)
Jersey Ram is on a distinguished road
Default Things I should look out for when buying a used 1996 dodge 2500 5.9L
Hey guys.
About to buy my first truck. It's a 1996 gas Dodge 2500 5.9L V8 engine with 130k miles. Guy selling it said he replaced a whole bunch of parts like shocks, water pump, belts and stuff and has receipts, but I haven't seen the truck yet.
Of course I'm going to crawl under it and try to look for oil leaks and stuff but I was wondering if any of you guys know about common problems with these years.
They prone gasket leaks? How long typical transmissions last on them?
Any info will be a big help.
thanks
Old 03-25-2011, 09:32 PM
Kilkenny's Avatar
Kilkenny Kilkenny is offline
Vehicle: 1996 Ram 1500
Rep:40
Kilkenny is on a distinguished road
Ask about plenum leaks. I have the same engine in my 1500 and it's in need of a plenum repair. The problem is the plenum plate on these engines being too flexible. It can be prevented with a stronger plate from Hughes Engine, but these engines can be prone to this problem with the OEM plate.
Other than that, I'd check the oil and transmission fluid when you look at the truck and make sure they both look and smell normal.
"Upon further review, we have determined that the shoestring is not a machine gun..."---Bureau of Alcohol Tobacco Firearms and Explosives, June 25, 2007
Old 03-26-2011, 07:05 PM
panhead's Avatar
panhead panhead is offline
Trim Level: WS
Rep:103
Have the guy lift the front end and see if the wheels got any play. It could be either bad ball joints or a bad wheels bearing which will run you $400 each.
As far as the plenum, they used a steel plate on an aluminum intake. Both metals have a different expansion rate when hot. Buy the updated intake gasket and plenum gasket from Mopar.
One to look for as well, check to see if the truck overheats. Last year when I bought my 96, it had the factory radiator. Didn't think anything of it but when the temps got warmer around here, the truck overheated.
Check the trackbar as well.
Old 03-26-2011, 07:08 PM
Plenum gaskets and trackbar links seem to be the recurring issues I read about on this generation truck with the 5.9L gas engine.
Of course, look for any other wear and tear items common with high mileage trucks.
Old 03-27-2011, 10:03 AM
97ram2500 97ram2500 is offline
Vehicle: 1997 Dodge Ram 2500 CC LB
Trim Level: SLT Laramie
Color: Emerald Green
97ram2500 is on a distinguished road
I always look to see if it has a brake controller or holes under the dash where a brake controller was mounted. On an automatic transmission I stay away if it's higher mileage and has been used to tow a lot of heavy loads with.
Old 03-29-2011, 11:29 PM
dewzram dewzram is offline
Vehicle: 2000 Dodge Ram 1500 4x4 QC
Rep:12
dewzram is on a distinguished road
I agree with these guys Jersey Ram, Plenum gaskets are very common issues, and of course the 46RH/RE (a518) auto transmissions. My 2000 Ram only has 74k miles on it and it's already on it's 2nd tranny and it slips from time to time on the highway. Also hear it's hard to find a 2nd gen Ram without the cracked dash, however I must have the rare gem that doesn't have a blemish on it. : ) Good luck, hope it's a keeper!
Old 04-02-2011, 01:23 AM
ScottLC's Avatar
ScottLC ScottLC is offline
Vehicle: 1998 1500
Rep:48
ScottLC is on a distinguished road
OK, I'll bite; $400? For hub assemblies? On a 96 4x4? I think the last set I bought didn't cost me 275 for the pair. I'd imagine 2wd wouldn't cost any more than that...
[CENTER][URL="http://www.ramforumz.com/www.libertydwells.com"]www.libertydwells.com[/URL]
[COLOR=Blue][B]"Once the monkeys learn they can vote themselves bananas, they'll never climb another tree." [/B][/COLOR][SIZE=1]- Heinlein[/SIZE]
[/CENTER]
Old 04-07-2011, 06:49 PM
panhead's Avatar
Trim Level: WS
Rep:103
Sure you can go the cheap route and have the bearings fall apart within a year. Its what the guy told me about when he bought his cheap wheel bearing/hub assembly. Timken sells the whole assembly together but they are very good bearings. They make heavy duty bearing for on road trucks and for the railroads. Timken also has a good warranty to back it up. Of course, the 2wd hubs are much cheaper than a 4x4 hub.
1996 dodge ram sport 360ci speedometer help/hp gain 1996dodgeramsport4x4 Newbie Checkin! 8 01-14-2011 09:21 AM
2005 Dodge 2500 Expected Fuel mpg maxwell Dodge Ram General Discussion 4 12-13-2010 07:10 PM
2006 Dodge Ram 2500 Laramie Mega Cab HEAVY DUTY Justin@AACstyle.com Dodge Ram For Sale - Used Dodge Trucks 7 07-21-2010 11:37 PM
Meet and Greet In The GTA Scheduled for Saturday October 25, 2008 300 Addict Dodge Ram Forum CANADA 35 10-24-2008 05:23 PM
getting rid of my 1996 Dodge Ram 1500 johnnie_5 Newbie Checkin! 7 08-19-2008 04:37 PM
