horrible noise - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Suspension
Old 03-25-2011, 11:48 PM
dodgedaddy dodgedaddy is offline
Vehicle: 1999 dodge ram slt laramie
Color: burgandy and silver
dodgedaddy is on a distinguished road
Default horrible noise
Hey guys I need a little help I just bought my dodge a little over a month ago its a ram. 99 1500slt laramie 2wd everything was perfect until a few days ago I hear a loud noise sorta like a squeaking/ screeching noise on my front passenger side when I turn right and also when I hit dips and divits on the road im thinking it could be my fittings because it does it a little when I turn to the left but that wouldn't explain the squeaks or the screeches coming from the passenger side any help woul be greatly appreciated thanks in advance
Old 03-25-2011, 11:56 PM
Rep:2962
just some thoughts
dry wheel bearing(s)
bad tie rod ends worn
if it were me i would go to an alignment shop & get a free inspection, then you can do it yourself or have them do it
Old 03-26-2011, 12:21 AM
foolioGrimz foolioGrimz is offline
Trim Level: 1500
Color: Green
Rep:56
foolioGrimz will become famous soon enough
these trucks are notorious for needing front end work. While ur at it get the ball joints replaced. I switched out just about everything on mine.. tie rods, ball joints, pittman arm, idler arm. Do the work yourself if you can Ive heard quotes of up to $1,500 for a shop to do it and you can get all the parts yourself for less than $500 if I remember correctly. I'll warn you that it is a PITA but well worth saving a thousand bucks in my opinion.
edit: there are two things you can count on with these trucks, You're going to lose the ball joints and the dash is going to crack. Other than that ive found it to be very reliable.
mods-Ranch hand Brush guard, superchip tuner, 75 gal transfer tank, 4.10 gears with detroit locker, 305/70-16 BFG mudders, 2" lift, Chrome Edelbrock carb filter with throttle body mod, and a short glasspack.
Old 04-06-2011, 12:40 AM
Well I figure im gonna go ahead and try the alignment shop thanks guys
Ram 2500 with engine noise. Big Ed 2010 Dodge Ram Forum 10 08-04-2015 02:03 PM
Help With "Whining" Noise From Rear??? GTR0419 5.2L V8 Specific Topics 5 02-07-2011 05:26 AM
Excessive Throttle Body Noise firedog318 5.9L V8 Specific Topics 8 01-23-2011 03:54 PM
whistle noise coming from under truck sledmanwinder LD RAM - General Discussion 6 06-15-2010 12:28 AM
98 dodge ram 1500 w/5.2l weird noise crazy1 5.2L V8 Specific Topics 5 01-17-2010 02:30 AM
