Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Suspension
Old 03-26-2011, 09:39 AM
ejk78 ejk78 is offline
Vehicle: 2004 Dodge Ram 1500
Color: Gray
ejk78 is on a distinguished road
Default Leveling questions....
Hey guys...
I have a 04 QC 1500 4x4, i wanted to level out the front end but dont really know much about it or anybody in the area that has done it.
I've seen people mention torson keys, and spacers. Whats the differance? Whats easier to do? What is better in the long run for the truck?
Thanks...
Don't go around....Com on its a RAM, just go OVER!!!!!
Old 03-26-2011, 11:43 AM
pettey78 pettey78 is offline
Vehicle: 1988 W-250
Trim Level: 88 rust
Color: Red & Black
Engine: 1989-1992 360ci (5.9L) LA V8 190hp
pettey78 is on a distinguished road
More than likely you have a IFS front end you will have to use the torsion keys to level out the front end. They are not to bad to install, had a Dakota that I lifted and it was the same.
Old 03-26-2011, 02:15 PM
Color: Gray
well i already have A/T tires on it and i was told the mechanic raised it with the torsion keys alittle already...so im not sure how much higher im aloud to go....also i read that everyone says to get the bilsteins 5100 cause they can be adjusted themselves, how hard is it to install the new shocks??? anybody install these on an '04?
Old 03-26-2011, 09:37 PM
Color: Gray
Ok, I was looking around and found these shock spacers. Can any one provide any feed back? I was searching the forums and found Hell Bent Steel spacers, but they dont have my truck listed!!! Its like the Red Headed step-child !!! WTF.. If you guys can give me any feed back. Thanks...
http://www.summitracing.com/parts/EX...Doors%7c4-door
Old 03-26-2011, 10:32 PM
ScatPak07's Avatar
Rep:970
You have a truck with torsion bars up front. That means you need to turn the keys to lift the front end. I bet those are the only spacers you will find for your truck....this is because it is wrong haha. Your truck does not have front coils to put the spacer onto. So you can just turn your torsion bars up to lift it. You should not turn them past a 2-2.5" lift or else you will compromise your ride quality.
You need to read info on your year truck man. The Bilsteins are only for 06+ Rams since they have coils in the front. You truck does not have this, the years would be 03-05 for your suspension needs. The Hell Bent Steel as with all other spacers will NOT fit your truck as well. I know your just learning and all but I want to make sure you dont buy something and have it not work on your truck. So like I said above go to that shop and get them to turn the keys a but more until the truck is sitting a little more level.
Good luck with everything man! If you need any help let me know I dont mind lending a hand
Old 03-27-2011, 08:54 AM
Color: Gray
Ok Thanks,
Now when you say to not raise it more than 2-2.5" with the torsion keys, what is that measured from( if that makes any sense) the top of the tire to the body, or is there a common area underneith?
Is there any others options for this, or are the keys it. And would it just be a better idea to do a lift kit? If raiseing it with the keys could compromise the ride (i've heard things could break to from to much pressure to) does it make more sense to do the lift kit if that would make everything safer and more derable. And would a lift kit also level it out?
Thanks
http://www.strutmasters.com/ReadyLIF.../rl66-1000.htm
has anybody tried these, these seem to be some of the best i found or is it overkill?
New '11, leveling kit, subwoofer adjust, debadging questions?? wisconcb 2011 Dodge Ram Forum 9 02-18-2011 05:40 PM
Leveling and wheel questions???? fuzzy Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 3 01-02-2011 10:27 PM
leveling kit questions Acheron Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 0 04-20-2010 10:58 PM
2009 leveling kit & tire sizes questions? RMS84MD 2009 Dodge Ram Forum 7 01-12-2010 11:19 AM
2009 leveling kit/tire size questions? RMS84MD Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 12-15-2009 09:24 AM
