Old 03-27-2011, 03:15 PM
garner's Avatar
garner garner is offline
Trim Level: Lonestar
Rep:46
Default First track visit
Took the truck out for it's first track visit and it was an ok night. There was very little traction because they didn't prep the track like they should've and it being 80+ degrees didn't help much either. Didn't get anywhere near the times I should've gotten. Hopefully next time I go out is better or I'll go to a better track. First run was a 14.749 @ 89 and best run was a 14.740 @ 87
Best run
First run
Gone but not forgotten:
First 2011 Ram R/T in Texas
Old 03-27-2011, 03:25 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Not a bad set of track times!!
Old 03-27-2011, 06:21 PM
platinuminjected's Avatar
Vehicle: 2009 dodge ram 1500
Rep:713
looks like decent numbers to me but like you said there not where they should be
Old 07-23-2011, 05:06 PM
TORMENTOR TORMENTOR is offline
Vehicle: 2010 Dodge ram 1500 Hemi
Color: Deep Sea Water Blue
Rep:156
TORMENTOR has a spectacular aura aboutTORMENTOR has a spectacular aura about
60 foot is fine so traction off the line isnt too terrible if your getting a 2.1. your 1/8th mile trap is correct, your just letting off to early at the finish line or your holding it in one of the gears and hitting the limiter. Either one, thats the only way your managing a 14 without breaking 90mph
2010 Ram 1500 Hemi Crew Cab 4x4
Bilstein 5100's maxed out, 305/55/20 Cooper Zeon LTZ's, 14" Magnaflow, K&N Drop-in, DiabloSport InTune, HemiFever tuned
Old 07-23-2011, 05:11 PM
garner's Avatar
Rep:46
This track you have to let off early. The distance from the 1/4 mile marker to the turn off is very short and tricky to slow down in time for even with a high 14 second truck
Old 07-24-2011, 01:59 PM
Rep:156
Well how are these other people trapping over 100 mph in your time slips? Either way, thats why your not running what you should be. Also im positive your track has another turn off further down. They would have been shut down for safety reasons if they didnt AND that would pretty much take away ANY kind of sports car or dragster from racing there so then they would go out of business.
I would look into that more
Old 07-24-2011, 02:04 PM
garner's Avatar
Rep:46
They have built cars and have made over 300 passes at this track. Could I trap higher and brake later? Yes. Am I comfortable doing so and possibly wrecking my truck? Not really since I have less than 10 visits and 20 passes in any of my cars. Also these runs were on bald factory goodyear fortera sl tires. Not gonna push my truck to the max when my braking is severely messed with by having bald tires. Gonna have to wait till late october or november when temps start getting down below 90+ at night to see what I can really do
Old 07-24-2011, 02:06 PM
garner's Avatar
Rep:46
The turnoffs are about 30 feet apart and nobody uses the first turnoff. Everybody uses the second turnoff
Old 07-25-2011, 12:45 AM
Rep:156
I am very surprised your track is still open if the turn offs are that close to the finish line. My track has 3 turn offs. the last one i dont even need to use the brakes, just let the truck glide to a slow its that far down. And its not some big national track, again, for safety reasons, im surprised your track is still even allowed to be open
Old 07-25-2011, 12:49 AM
garner's Avatar
Rep:46
Here's the track's picture album, http://s1135.photobucket.com/albums/...cpZZ2QQtppZZ36 . Shows you how small the track is. You can't even drive around the waterbox, you have to drive through it no matter what. So you're really screwed if you have an open rearend like I did in my genesis since only wheel gets the water off of it
Drag Racing Tips dodgeman70592 Drag Racing Discussion 32 04-26-2014 09:33 PM
mygig HDD playlist and track playback davidreed Dodge Ram General Discussion 1 06-22-2012 12:06 PM
1/4 mi track times tex02 Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 9 02-24-2010 09:19 PM
Finally made it to the track! smartel 2009 Dodge Ram Forum 15 02-24-2010 08:33 AM
Big Yellows day at the track! Brian08 Dodge Ram Pictures - Photos 9 08-04-2009 04:59 PM
