Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Old 06-02-2011, 12:39 AM
jpmassa jpmassa is offline
Vehicle: 1991 Ram D250 5.9L
Trim Level: LE
Color: White peeling to primer
Engine: 1989-1992 360ci (5.9L) LA V8 190hp
jpmassa is on a distinguished road
Default Idle Speed Motor (AIS) problems code 25
Sorry I posted this on 5.9 L specific forum first. Thought this forum might be better suited.
Any one offer some advice on fault code 25 problems? Recently had to replace the SBEC / engine computer. After replacement, got a new fault code I never had before = 25. Sure enough, the idle speed motor (AIS) motor attached to the throttle body stopped working immediately after engine computer replaced ... low idle, engine wants to die out at idle especially under load, no movement at all at the AIS motor.
Coincidence that the motor failed after ECM changed? So, then I replaced the idle speed motor for $75, but problem is not fixed, code 25 remains. Now I'm thinking maybe the engine computer is faulty here .. can't tell. No diagnostics in the CHilton manual for this one. Can't find any wiring problems. Suggestions for diagnosis? Or just replace the AIS motor again or replace the ECM (again)?
Thanks for reading, Jim.
Old 06-02-2011, 08:40 PM
frealz13's Avatar
frealz13 frealz13 is offline
Vehicle: 2001 ram 1500 4x4
Trim Level: slt laramie
Color: blue silver
frealz13 is on a distinguished road
its on chapter 6-33 in the haynes book if you dont have one post back and i send you what it says
-PAT-
Old 06-02-2011, 10:18 PM
Trim Level: LE
Don't have Haynes' manual. If you do get a chance, I'd be eager to know more about that section. Jim
Idle Speed Motor (AIS) problems code 25 jpmassa 5.9L V8 Specific Topics 3 06-05-2011 09:59 AM
Idle problems rflearyjr 5.7L V8 Specific Topics 3 05-03-2011 11:28 AM
4.7 idle problems Audiowizard 4.7L PowerTech V8 Specific Topics 10 02-24-2011 01:14 AM
Low Idle Speed Straightedge 5.7L V8 Specific Topics 5 03-14-2010 08:18 AM
99 5.2 idle speed Dieselkiss 5.2L V8 Specific Topics 1 03-09-2010 06:53 PM
