Old 12-22-2012, 01:15 PM
5point7John's Avatar
5point7John 5point7John is offline
Vehicle: 2008 Dodge Ram
5point7John is on a distinguished road
i used to have a cheap cobra radio and antenna from walmart. only cost $50. worked good for talking to your buddies while you are wheeling. i never wanted a serious cb or a permanent one so i just used a 12v adapter for power and ran the coax through the rear window then i would take it out when i wasn't using it.
08 Ram 1500 BigHorn 4x4 Hemi SOLD! 2011 F250 6.7 PSD
Old 12-24-2012, 04:44 PM
cemeflybyu cemeflybyu is offline
Vehicle: 2006 Ram Big Horn
Trim Level: Big Horn SLT
cemeflybyu is on a distinguished road
Rkeytek...I like the folding antenna. Where did you get the stake pocket mount?
Old 12-24-2012, 04:50 PM
OP...with several years of trucking driving experience I've used several different CB's. For the use you are describing a Cobra 29 will do all you need and then some. The big thing you need to be sure of with whatever you get is the check the SWR reading once your radio and antenna are hooked up. If they are too high you will had bad TX/RX and you will end up burning up the radio. You can buy a cheap SWR meter if the radio you buy does not have one built in. You can lower the SWR by shortening the whip length. Remember...only cut small amounts...what you take off cant be put back on.
Old 12-29-2012, 12:25 AM
aedwardzo aedwardzo is offline
Vehicle: 2009 Dodge Ram
Color: Light Graystone
Rep:57
aedwardzo will become famous soon enough
I had dual firesticks on my last ram. had them mounted to to the tool box. They looked aweswome and saved my a** a couple times when i had to call some friends to come pull me out! good luck
mods..... Too much to list! check my mod list!
http://www.ramforumz.com/member.php?u=58666
Just picked up my new 2011 ram sport! slikkwilly002 Dodge Ram General Discussion 21 02-23-2011 08:39 AM
CB Radios? JakeRam02 Custom Dodge Ram Interior Modifications - Custom Audio / Video 5 10-15-2010 06:34 PM
Din Size for 06 Ram radio's 1BigHemi Custom Dodge Ram Interior Modifications - Custom Audio / Video 3 07-05-2010 09:58 PM
Needing some info on radios franklinco911man Electrical 4 04-12-2010 11:22 PM
