Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Suspension
Old 03-28-2011, 12:36 AM
bucmachine bucmachine is offline
Vehicle: 2011 Dodge Ram
Trim Level: Sport 4x4
bucmachine is on a distinguished road
Default Air Lift 1000 install.
I was wondering if I need a wheel alignment after I install rear coil helper air bags? I will be taking the coil out to install these due to the large spacer. Thanks in advance!
Old 03-28-2011, 02:42 AM
theweavman theweavman is offline
Vehicle: 2009 Dodge Ram 4X4
Trim Level: Laramie Crew Cab
Color: Austin Tan Pearl &Lt. Graystone Pearl
Rep:27
theweavman is on a distinguished road
I installed these, didn't need to remove anything other than the tire and wheel....Have not had any alignment issues....I have a 2 inch Daystar front & rear lift kit installed, but I did get an alignment after putting in my lift kit however.......The air bags go in easy if you follow the instructions....whole job took about an hour...good luck
So it is written ! So it shall be done!
Old 03-28-2011, 12:39 PM
The spacer for the top of the air bag is 2.5" tall, how did you fit it between your coils?
Old 03-28-2011, 02:37 PM
Rep:27
The spacer that came with my Air Lift 1000, kit, as I recall was only about an inch to an inch and a half or thick, it slipped right when the coils were extended from the rear end not having any weight on it.... You may want to verify that you got the right kit, or that they put the right spacers in your kit... Mine was for a 2009 Ram 1500 Laramie 4X4 Crew Cab... And was an easy install...
Old 03-30-2011, 10:12 PM
CHVYKLR's Avatar
CHVYKLR CHVYKLR is offline
Vehicle: 2009 Ram Crew 2WD
Trim Level: Lone Star
Rep:252
do you guys both have the kit with the p/n 60818?
Old 03-30-2011, 10:38 PM
Rep:27
Yes, my kit # was 60818, hope that helps
Old 03-30-2011, 10:55 PM
CHVYKLR's Avatar
Rep:252
I have 60818 but haven't installed it yet and my spacers are also about 2-2.5 inches. maybe a call to Airlift is in order to figure this out. I'll be pretty upset if I rip the rear coils out only to find they sent my the wrong kit.
hey weaveman, is there any space between the spacer and the truck bed when it's empty.
Old 03-31-2011, 12:40 AM
Rep:27
Hey guys, first I'm sorry that I don't remember the exact thickness of the spacers that were in my kit... Second, I have a DayStar front & Rear lift kit installed. Third, there is a factory upper spring retainer, so the airlift spacer goes up and touches that piece, not the bed... Again with the weight off the rear end, and the springs extended, the spacers that came in my kit easily slipped in thru the spring onto the top of the air bags...once inflated the bags hold them in place... I keep about 12psi in them normally... I also put alittle bit of o-ring lube onto the line fittings to improve the sealing and ease the installation of the air lines onto the fittings... I've so far not had any leaks... I'd like to help more, but don't know what else to say, I can't get to my spacers anymore to see or measure them... Sorry
Old 03-31-2011, 09:23 AM
CHVYKLR's Avatar
Rep:252
thanks for the clarification. I forgot about the spring retainer. I'll take a closer when I go to install them.
Old 03-31-2011, 10:39 AM
Blue Streak Blue Streak is offline
Vehicle: 2011 Ram 1500 Sport 4x4
Rep:63
Blue Streak will become famous soon enough
Where did you instal the air lines? Any pics?
07 ram 1500 body lift install? jdanthony26 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 26 11-19-2011 05:31 PM
Lift Install ThunderRoad Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 5 03-25-2011 01:28 AM
Question on Lift and Tires alfredenewman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-14-2011 10:49 PM
Opinions needed for tire and lift additions... lots of reading haha ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 42 02-09-2011 11:25 PM
Normal price to install body lift? sinistersix Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 8 01-07-2011 01:07 PM
