Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
tonneaucovered.com
Old 03-28-2011, 11:20 AM
4x4 ramher's Avatar
4x4 ramher 4x4 ramher is offline
Vehicle: 03 ram 1500 4x4
Color: gray
4x4 ramher is on a distinguished road
Default check gauges light, no oil pressure
So i start the truck light comes on check gauges, i look at the dash didnt realize no oil pressure so i drive about 50 yards then it hits me i pullover shut the truck off check the dip stick oil looks good. i start it back up oil pressure jumps right up to normal.... what should i look for or do before catastrophic failure.
Old 03-28-2011, 11:39 AM
Resident Technician
Rep:1911
Could be a clogged pickup or just a sending unit. Confirm the loss of pressure with a mechanical gauge and then go from there.
Old 03-29-2011, 09:34 PM
4x4 ramher's Avatar
Color: gray
how do i hook up a mechanical oil gauge?
Old 04-08-2011, 02:09 PM
KingRam KingRam is offline
Vehicle: 2002 ram 1500
Color: red
KingRam is on a distinguished road
I have the same problem but it only does it at idle or when its a quart low. And only after the truck is up to normal operating temp
Old 05-18-2011, 12:41 AM
bates1's Avatar
bates1 bates1 is offline
Vehicle: 1995 dodge ram 1500
Trim Level: larame
Engine: 1989-1992 360ci (5.9L) LA V8 190hp
bates1 is on a distinguished road
i also have a 03 ram with a 4.7. mine used to do that also. i took it to multiple dealerships they all said nothing was wrong. i drove it from my friends house in Louisiana to leesburg fl. and had catastrophic failure. it spun a main bearing on it and slung 2 rods. luckily i had extended warranty. the motor had 89k miles. a dealership replaced the motor $6k for mopar reman. they could not tell me the cause of it. i had just purchased it less than 2k miles. i think there was sludge in the motor but the dealership explained if there was warranty would not have covered it.
Cant dodge it, Ram it!!
Check engine light southpaw5m 4.7L PowerTech V8 Specific Topics 11 06-08-2011 12:34 PM
New FIPK K&N Filter then check engine light? Ostranza 5.7L V8 Specific Topics 4 12-04-2010 01:59 PM
Check Engine light col Oil Change 14 11-26-2010 10:23 PM
TPMS Tire Pressure Monitor Light 2010 351 Stang 2010 Dodge Ram Forum 6 08-28-2010 12:59 PM
Check Engine Light TFC66 Electrical 5 03-25-2010 07:06 PM
