Best Spark Plugs - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 03-28-2011, 11:41 AM
alfonso318's Avatar
alfonso318 alfonso318 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: 1500 (5.9L)gas
Rep:42
alfonso318 is on a distinguished road
Default Best Spark Plugs
Looking to replace the spark plugs...i was told autolite doesnt work well with Dodge...which ones should i get?
Old 03-28-2011, 12:15 PM
Resident Technician
Rep:1915
For your truck, get the Champion RC12LC4 and gap them to .040"
Old 03-28-2011, 01:03 PM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
i know i don't have the same truck/engine but the thread caught my eye....and i should probably do a tune-up while i've got all kinds of work being done anyways......
do you have a different brand/part number that you recommend? (besides Champions?)
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
Old 03-28-2011, 01:17 PM
Resident Technician
Rep:1915
NGk but I don't have the part number handy.
Old 03-28-2011, 02:08 PM
sdram03's Avatar
Rep:52
kk. thanks. at least it gets me in the ballpark.
Old 03-28-2011, 09:52 PM
Mountainman's Avatar
Mountainman Mountainman is offline
Vehicle: 1998 Dodge Ram 1500 4x4 Sport
Color: Viper Blue
Mountainman is on a distinguished road
Alfonso318, I am not a big fan of Champion spark plugs either. Autolite is about the same. If you compare the electrode centers on them, they are not consistent from one to the next, and, can very greatly. By greatly, I mean .03125 or about 1/32. It is a high voltage circuit, which means that the electricity does not care much about that kind of error, however, immediately, and as the plugs wear with use, it will create slight differences in their performance. In other words their will be hot spots on some plugs making them wear faster, and unevenly, compared to other plugs (in the same batch) that have a more generalized current flow pattern. This more generalized flow pattern, will produce a more consistent burn of fuel/air and is the idea behind the NGK "Hot U" and other exotic design spark plugs. In addition, I can tell you from personal experience that in a 2 cycle motor (your 5.9L is a 4 cycle) I get at least 5 times (not an exaggeration) the life out of a NGK spark plug than I get with Champion. (Heat range is more critical in 2 cycle motors) This is a very condensed version of high voltage/resistance circuits. The easy answer is quality matters way more than price. BTW Consistent gaps are more important than many people think too. Hope this helps.
Lifted 1500 Sport 4x4 360" Gas guzzler
Old 03-29-2011, 11:05 AM
swmpsngr swmpsngr is offline
Trim Level: Laramie- SLT
Color: Red over Gray
swmpsngr is on a distinguished road
I have a 5.9 engine in my 2001 Ram, I put E3 plugs in it and after a few rough miles I have found they work great...Mileage is up and the miss I had at Idle is gone. Cold starts in the winter are quick and clean.
Old 03-29-2011, 11:22 AM
3rdgenluder 3rdgenluder is offline
Vehicle: 2006 ram 1500
Trim Level: slt quad cab sport
Color: RED
3rdgenluder is on a distinguished road
normaly i run boch platums in my cars but this is my first HD motor (my other cars i ran bosch plat+4) and the fact that i need 8 plugs kinda makes me shy away from this high priced plug....and i have had the e3 recommended to me buy another person as well...anyone else running e3 plugs?
Old 03-29-2011, 11:28 AM
sdram03's Avatar
Rep:52
are Iridiums really worth it? or just pointless...
Old 03-29-2011, 11:45 AM
Color: RED
i understand the forced air guys like the iridiums on the import cars and what not...not so sure about a HD engine though... another example of pricy plugs that better perform exceptionaly well and give better everything.
New Spark Plugs flndrpndr23 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 25 08-10-2013 08:32 PM
Did I not get the memo about spark plugs? Rusty Nib 5.7L V8 Specific Topics 15 04-08-2011 11:32 PM
Spark Plugs?? 2008BIGHORN Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 11 03-27-2011 10:18 AM
8 spark plugs vs. 16 spark plugs Basic Corpse Newbie Checkin! 16 01-04-2011 11:23 PM
how to install spark plugs and remove them moparmike07 Dodge Ram Knowledge Base 24 07-06-2010 09:42 AM
