tonneaucovered.com
Old 03-29-2011, 12:13 PM
Resident Technician
Rep:1911
Originally Posted by sdram03 View Post
are Iridiums really worth it? or just pointless...
If you want longevity, sure, they're worth it. I prefer to change mine every 30K so I have a chance to read the plugs and see what's happening inside the cylinders.
Old 03-29-2011, 09:12 PM
alfonso318's Avatar
alfonso318 alfonso318 is offline
Vehicle: 2001 Dodge Ram 1500
Trim Level: 1500 (5.9L)gas
Rep:42
alfonso318 is on a distinguished road
So i put in the champions that RamTech suggested....seemed to fix the check engine light...when i started it up it idled pretty good...when i reved it a few times and ran it up to 4000 or 5000 it kinda did some weird like sputtering at the higher RPMS...any thoughts? Typical?
Old 03-30-2011, 12:06 AM
3rdgenluder 3rdgenluder is offline
Vehicle: 2006 ram 1500
Trim Level: slt quad cab sport
Color: RED
3rdgenluder is on a distinguished road
what did you change out of it?
Old 03-30-2011, 12:15 AM
alfonso318's Avatar
Rep:42
i took out Autolites or w/e they were...i was told they were crap for dodges...so i put in the Champion ones suggested by RamTech...
Old 03-31-2011, 12:35 AM
panhead's Avatar
panhead panhead is offline
Vehicle: 1996 Dodge Ram 2500
Trim Level: WS
Rep:103
My Neon and Ram both call for Champions, I would not touch them even with a 10ft poll. I run NGK's Iridiums in my Neon and NGK V-Power in my Ram. I am very please with NGK. The Echo equipment I have all call for NGK's. Well worth the money.
Old 04-02-2011, 02:03 PM
97ram2500 97ram2500 is offline
Vehicle: 1997 Dodge Ram 2500 CC LB
Trim Level: SLT Laramie
Color: Emerald Green
97ram2500 is on a distinguished road
I have run NGK's in all my quads and my Raptor ended up blowing a headgasket and turned the plug to crap. After changing the head gasket I cleaned the plug with a wire wheel and put it in and it still worked great. I can't say the same for Champions.
My truck came with champions in it and only had 3,000 miles on them and so far no problems. But if I were to buy new ones I'd probably buy NGK's.
Old 04-02-2011, 03:10 PM
hemiluv54 hemiluv54 is offline
Vehicle: 2008 DODGE RAM
Color: LIGHT KHAKI METALLIC CODE -PJC
hemiluv54 is on a distinguished road
Default E3 Spark Plugs
I would like to change the spark plugs in my 4.7 and was looking at the E3's.Anyone with experiance of this product would be appreciated.I have heard good and bad about these plugs.What's the real deal.These plugs are insane expensive so before i spend my money i would like some input on this product.Thanks. Hemiluv54.
Old 04-02-2011, 04:51 PM
Rep:2720
some vehicles just run better on different spark plugs
my Harley shovel head runs best on Autolites, my buddies Harley runs best on NGK. We both use different carburetor brands
_______________________________________
spark plug company history & facts
Motorcraft & Autolite are made by Honeywell, the company also makes FRAM
NGK makes it own products
AC DELCO is a division of General Motors
Champion was made Albert Champion, sold to Cooper Industries in 1989, now owned by Federal-Mogul Corporation, the same company owns Moog, ANCO, FEL-PRO, WAGNER Brakes, Wagner Lighting
Champion also builds spark plugs to SPEC for several companies
For many years Harley-Davidson Spark plugs have been manufactured by 'Champion Spark Plugs'. H-D has a contract through Champion for the optimum heat range for H-D street motors, this heat range is only available on H-D plugs and is not sold in stores
Hot & Cold HEAT RANGES are explained quite well here
http://www.harleyhelp.com/sparkplg.html
BOSCH makes their own plugs
Bosch has also purchased 50% of Purolator Filters as a joint venture with Mann+Hummel.
Old 04-09-2011, 05:54 PM
the83judge's Avatar
the83judge the83judge is offline
Vehicle: 2001 Dodge Ram 1500 O/R
Trim Level: Off Road package
Color: dark green
the83judge is on a distinguished road
My best friend and my father-in-law both swear by BOSCH Platinums. The good thing is they come pre-gapped for your application. I plan to get them for my next plug change.
If you can't dodge it, RAM it!
Old 04-10-2011, 10:10 AM
sdram03's Avatar
sdram03 sdram03 is offline
Vehicle: 2014 RAM 3500 Big Horn
Color: Maximum Steel
Rep:52
sdram03 will become famous soon enough
read: check em anyways.
BTDT and don't trust any company. have had it happen quite a few times where they may have been dropped or whatever. so i check em. that's just me. part of the process and enjoy doing it.
if you're gonna go, go with a smile!
2014 RAM 3500 Big Horn CTD CC 4wd in Max Steel
New Spark Plugs flndrpndr23 Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 25 08-10-2013 08:32 PM
Did I not get the memo about spark plugs? Rusty Nib 5.7L V8 Specific Topics 15 04-08-2011 11:32 PM
Spark Plugs?? 2008BIGHORN Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8 11 03-27-2011 10:18 AM
8 spark plugs vs. 16 spark plugs Basic Corpse Newbie Checkin! 16 01-04-2011 11:23 PM
how to install spark plugs and remove them moparmike07 Dodge Ram Knowledge Base 24 07-06-2010 09:42 AM
