Old 05-12-2010, 10:50 PM
Cormacs's Avatar
Cormacs Cormacs is offline
Trim Level: Crew Sport
Rep:14
Cormacs is on a distinguished road
Default Cool Accesory
Anyone get these yet? I finally finished installing them today. It is a mopar accesory part #82210928AB. Pretty simple to install, the wires from each side meet up on the driver side then run to the front and go through the firewall. The instructions tell you to wire them to the dome light but I changed it and wired it to the cargo light. I thought it would be better wired to the cargo light. I always found it dark in the bed at night with the tonneau cover on, not any more. Sorry for the not so good picture quality.
Old 05-12-2010, 10:53 PM
iRESQu iRESQu is offline
Rep:2217
Nice work! I like it a lot! Thanks for the write-up and pics.
Old 05-12-2010, 10:55 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Smile
Hey that looks really cool, I was interested in these as well. A few questions, where on the firewall did you run the wires through (any chance you can post a pic). Also, the wiring into the cargo light, how did you do that and what wires did you use ? How much did they cost and would they fit the Quad cab ?
Old 05-12-2010, 10:56 PM
Cormacs's Avatar
Rep:14
I know someones going to ask. I fogot to add that the lights are two way taped on to the inside edge of the bed rail. I'm not a fan of the two way tape but it seems to be holding.
Old 05-12-2010, 11:00 PM
Cormacs's Avatar
Rep:14
My truck is a crew cab with the small box so yes they should fit in any box. because of the tonneau cover I had to modify the mounting locations but the light bars are not all that long and they give you a fair bit of wire between them so you can use imagination as to where and how far apart to mount them. I ran the wires through the grommet used for the gear shift cable, its easy to get to and lots of room to run wires through. The wires for the cargo lamp are in the big connector by the drivers left foor if you were to be sitting int the truck. The power wire is a white wire with a tan tracer and I found a ground up in the left dash cap panel, a black with brown tracer. If you want to wire them with the dome light as directed by the instructions the power wire is where I got the ground in the left dash end, a green connector.
Old 05-12-2010, 11:09 PM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
Smile
Thanks for the info, your cp says Crew sport which is why I asked about Quad cab. Also, how much did they cost. I asked about where on the firewall because the people who installed my Leer drilled a hole in the floor right beside the wiring harness, lazy and cheap bas&^&**#s. I will re-route and fix their screwup and power the dome light from the cargo lamp circuit. Was thinking of adding the light bars as well. Thanks for your reply.
Old 05-13-2010, 02:56 AM
Rep:2657
I believe that i read a post some where about a boot that surrounds the steering column under the hood, & that in that boot there is a dimple or protrusion below the column, it was made to run electrical wiring through. sorry i don't remember the years that had it
Old 05-13-2010, 07:42 AM
Rep:1625
That's awesome, thanks for the pics
Old 05-13-2010, 08:03 AM
trx4's Avatar
trx4 trx4 is offline
Vehicle: 2006 Q-Cab
Trim Level: SLT TRX4
Rep:45
trx4 is on a distinguished road
that is cool
Old 05-13-2010, 08:06 AM
Boubou's Avatar
Boubou Boubou is offline
Vehicle: 2010 Dodge Ram QC 4X4 Hemi
Trim Level: 4X4 SLT Hemi
Color: Light greystone
Rep:54
Boubou will become famous soon enough
Love it! Great idea to hook it up to the cargo light. That's on my wish list for mods
