Old 03-28-2011, 04:08 PM
Dninty9 Dninty9 is offline
Vehicle: 1997 ram 4x4
Dninty9 is on a distinguished road
Default 3.5" lift
I just got a set of 3.5" lift spacers for the front. I wanted to get your guys knowledge on what else I will need to complete the lift. The truck is a 97 1500 it is mainly used on ranch land so no real need for a lot of flex. What size lift will the rear need to level it out? thanks
Old 04-08-2011, 01:51 PM
Mondo707 Mondo707 is offline
Vehicle: 2001 1500
Trim Level: Slt
Mondo707 is on a distinguished road
i used a 21/2'' coil spacer and 2'' and it seemed to even out the front rake my truck had.. its not compleatly level and the front still comes down lower then the rear... hope this helps
Old 03-19-2012, 10:19 PM
ramz02 ramz02 is offline
Vehicle: 1998 Dodge Ram
Trim Level: SLT Laramie
ramz02 is on a distinguished road
Depends on how level the truck is once you install the 3.5" lift . You will probably need longer shocks as well . 3.5" seems like it will make the front sit higher so a 1.5" rear block would work to level it out and lift the truck all around .
1998 Dodge Ram 1500 - 2WD 3" level w/ 1.5" rear block
Old 03-25-2012, 07:44 PM
Big Green V10's Avatar
Big Green V10 Big Green V10 is offline
Vehicle: 2000 Dodge Ram
Color: Green
Rep:31
Big Green V10 is on a distinguished road
Do not stack blocks please just get a new block 1 1/2 to 2" taller than the factory one. I recomend control arms and shocks for 3.5"
2000 Dodge Ram 2500 4x4 Ext Cab V10, 12" Suspension, 3" Body, 46x19.5x20 Baja Claws
Question on Lift and Tires alfredenewman Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 2 03-14-2011 09:49 PM
Comparison Photo's - Tire Size & Lift Quiet Lunatic Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 30 03-14-2011 05:59 AM
Opinions needed for tire and lift additions... lots of reading haha ScatPak07 Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 42 02-09-2011 10:25 PM
2010 Ram 1500 4X4 Lift Help! Cap10crch 2010 Dodge Ram Forum 6 03-02-2010 11:28 AM
Suspension lift vs body lift usmcoorah Custom Chassis - Drive Line - Suspension - Wheels and Tires - LIFTING - Dodge Ram 4x4, 2x4 10 06-19-2009 12:13 AM
