Old 03-28-2011, 10:21 PM
flip203 flip203 is offline
Vehicle: 2004.5 Ram 2500
Trim Level: SLT 4X4
Color: Blue
Engine: 2004-2004 359ci (5.9L) Cummins ISB 600 24-Valve Diesel I6 325hp 600lb/ft (6-Speed Manual)
flip203 is on a distinguished road
Default Twin headlight question? Please help.
I recently changed my head lights to sonar projector headlights. This headlight set up changes the single factoy bulb to a low beam projector H1 (HID) and a seperate H1 high beam. The problem I have is that when I switch to high from low the ballast has to start warming up and there is a period of low visibility driving. Roughly about 2-3 seconds worth. Is there a way to make the low beams come on when the high beams are on? That way the ballast never shuts off between high and low. I use my high beams driving down country back roads and the ballast will completely cool down before I will encounter another car for the most part. I have a 04.5 2500. Thank you.
Old 03-29-2011, 12:02 AM
wigbill98 wigbill98 is offline
Vehicle: 2009 Dodge Ram
Rep:44
wigbill98 is on a distinguished road
Yes there is a way to setup a jumper in your fuse box. I am unsure being's I don't have your wiring diagram.
-Will
Mods = Retro-Fit Projectors & HID's with painted housing, Welded Muffler, VHT Nite-shades Chrome License Plate Frame...OH YEA!
Old 03-29-2011, 12:08 AM
Is the high beam bulb also HID? They do need to warm up and it takes a few seconds so that's why I don't use them in the high beams.
Old 03-29-2011, 08:19 PM
Trim Level: SLT 4X4
Color: Blue
The high beams are standard H1 bulbs for now. The high beam warm up wouldn't be much of a problem because the low beams would stay on the whole time. Hence th need for a solution because I would like to have HID Highs too.
Old 03-31-2011, 01:38 PM
dustin72's Avatar
dustin72 dustin72 is offline
Vehicle: 2013 Dodge Ram1500 4x4
Rep:48
dustin72 is on a distinguished road
There is a company from Edmonton Alberta called beamershids.com that sells a special wiring harness kit just for situations like yours. I installed it on a customers truck that switched from the dual headlights to the quads. I also installed HID kits on the low and high beams. This harness kit will solve all flickering issues as well as allowing the high and low beams to stay on together. Give them a call and tell them your situation. They will hook you up.
Black SRT10 22's with 305/45/22 Nitto NT420S Tires, 6000k Low and Fog HID's, Debadged, Tint, Custom Mopar Badges, S&B Intake, Magnaflow Muffler, Superchips Tuner
question: headlight sizes... bigC310 Custom Dodge Ram Interior and Exterior Lighting 3 12-20-2011 01:52 AM
headlight question 464 Electrical 1 11-16-2010 11:22 AM
Stupid headlight question beermanjoe Custom Dodge Ram Interior and Exterior Lighting 11 06-20-2010 01:02 PM
2001 headlight question jacked01dodge Custom Dodge Ram Interior and Exterior Lighting 9 04-16-2010 02:15 AM
Headlight question.. Jus Dodge Ram General Discussion 15 11-21-2009 11:41 PM
